Results 1 to 6 of 6
- Dec 2002
- 124
November 14th, 2010 08:57 PM #1May problem po yung 2010 Strada GLS Sport AT ko. 10 months pa lang po ito. Ayaw na niya magstart. Check ko yung ignition fuse (40A) sa engine bay nakita ko pumutok. Tapos pinalitan ko ulit ng bago pero pagka lagay ko pa lang sa ON ng susi pumutok nanaman ang fuse. Ano kaya ang nag short sa system? Mga ilaw, lock gumagana. Pero yung alarm ayaw gumana. May reason kaya yung alarm system sa pagputok ng fuse?
November 14th, 2010 09:10 PM #2
wag mo na pilitin na paandarin at baka mas dumami pa yung electrical problem lalo na kung pumuputok yung fuse everytime na sinusubukan mo i-on yung ignition...Kung insured pa yan or under warranty pwede mo naman tawagan ang insurance/casa company pa i-tow yung unit going to casa at para dun na nila ma-check-up ng ayos. At kung malapit lang yung casa mo pwede sila na rin ang pumunta sa bahay mo or pwede rin na mag dala sila ng tow trucjk kung sakaling ayaw talaga umandar.
November 14th, 2010 09:11 PM #3
im no expert, pero on the way you describe it parang yung problema nasa alarm.original alarm pa ba or pinalitan mo na ng alarm? Better have the casa take a look, covered pa naman siguro ng warranty yan sir.
alternative would be a good car electrician.
- Dec 2002
- 124
November 14th, 2010 09:29 PM #4Actually may nakasched na dito sa bahay na mechanic from casa. Gusto ko lang sana malaman kung mayroon na naka-experience nito para mas madali ma troubleshoot. Napalitan na rin steering column around 4 months ago kaya baka ayun din ang problema. Baka hindi maganda pagbabalik ng electricals. Alarm is original. When I replaced the fuse the alarm worked. Pero nun nilagay ko na sa ON ayun pumutok nanaman ang fuse. Ayaw nanaman gumana ng alarm.
November 14th, 2010 10:10 PM #5
Bro - better to follow the advise given above, fuse is created to protect the electrical and electronic system. It is designed to open the circuit in case of an infinite surge of current - known as shorted circuit--- ito un pag pop o pagsabog ng fuse natin. Huwag mo ng subukan ulit baka lumala ang problem.... isa rito ang pag sunog ng wire since ang shorted na circuit ay nabibigay ng mataas na amperahe. Hintay na lang pards ng gagawa.
One feature they should incorporate in EVs is speed limiting based on the keyfob you hand over to...
