Results 1 to 4 of 4
June 10th, 2012 03:33 PM #1
I have been seeing Strada GLX installed the stock mags, if you are one of the owners, would appreciate your feedbacks.
The looks is growing on me recently eh. I do not want to change kasi the stock mags..
No handling issues?
FC drops? Ilan po ang nabawas?
Any other issue?
June 13th, 2012 10:55 PM #2
I believe it's 265/70r16 tires (all-terrain being the popular choice). Many have mounted this tire size on the stock 16x6 wheels of the Strada GLX but it's already outside the tire manufacturer's recommended rim width for the tire size (7 inches minimum; 8 inches optimum; 9 inches maximum). Some just inflate to a higher pressure to avoid rim-cut (occurs when wider tires are mounted on narrow wheels on normal or relatively low tire pressure) such as 34 psi. But ride comfort is sacrificed along with tread wear (becomes centered instead of even road contact). If you like a stock-look, try searching for 2008-2009 Strada stock wheels. I think they are 16x7 which is within the recommended rim width for 265/70r16.
June 18th, 2012 01:40 PM #3
Thanks forn reply and your input on the tire cut. My bad, my GLX rim is 16'' and not the 15''.
I am now looking for either a GLS latest design or Monty mags.
June 18th, 2012 05:02 PM #4
just seen a 10th gen cross 200,000 miles on reddit. is this a unicorn or has the cvt been proven...
All New 2016 Civic
