Results 41 to 50 of 92
March 28th, 2013 01:15 AM #41
VIC is overprice as far as im concern. A good oil filter would cost you less than half the price of VIC filters. Kung same price lang or much cheaper ang VIC, then it could be an option.
March 28th, 2013 02:05 PM #42
April 4th, 2013 08:33 AM #43
April 4th, 2013 08:44 AM #44
ang tagal din kasi na naging default replacement filters ng mga kotse (outside of OEMs) dito kaya siguro malakas ang loob magtaas ng presyo
lately lang ako nag-try ng baldwin filters tapos nabili ko lang din through a fellow tsikoteer who sells them. talagang sadyang bihira makabili ng baldwin, bosch, etc outside of manila
April 28th, 2013 11:28 PM #45
Same lng ba part number ng oil at fuel filter for 2.5 and 3.2 engine? If not can someone tell me the part number for 3.2? I mean for baldwin filters tnx.
April 30th, 2013 08:25 AM #46
- Aug 2003
- 317
April 30th, 2013 10:55 AM #49I'm confused with the Baldwin Fuel Filters. Are both BF7535 and BF534 compatible with our pre-2012 Montero and Stradas? I am seeing both part numbers while reading the forums..
But when I accessed the Baldwin site, OEM 1770A053 is crossed with the BF7535.
My BD28 I got from a fellow Tsikoteer..
Tsikot Member Rank 1
- Jul 2009
- 4,090
April 30th, 2013 04:42 PM #50here is your answer.
2008-2011 monty and strada 2.5 or 3.2 will have no problem fitting bf7535. regarding bf7534, pajero and advie, perfect fit, but on monty and strada, case to case. i for one used 2 pcs of bf7534 and no problem. an officemate and prince777 had fitting issue with it(7534), they had to change to 7535, considering their montys are also 2011 model same as mine. bottom line it is safer to use 7535 on monty
Automatic po Sir
