Page 5 of 10 FirstFirst 123456789 ... LastLast
Results 41 to 50 of 92
    Oct 2011
    #41
    VIC is overprice as far as im concern. A good oil filter would cost you less than half the price of VIC filters. Kung same price lang or much cheaper ang VIC, then it could be an option.
    #42
    Sikat na siguro sila kaya nagtaas na ng presyo.
    #43
    Quote Originally Posted by roydok View Post
    The bggest problem with vic filters is there are so many fakes coming from china.
    Sa abad santos sta cruz manila, saw anoher importer of baldwin filters, just got my bd28, 7028 anf bf 7535 fuelfilter from them,
    Price is same with volmax.
    #44
    ang tagal din kasi na naging default replacement filters ng mga kotse (outside of OEMs) dito kaya siguro malakas ang loob magtaas ng presyo
    lately lang ako nag-try ng baldwin filters tapos nabili ko lang din through a fellow tsikoteer who sells them. talagang sadyang bihira makabili ng baldwin, bosch, etc outside of manila
    Feb 2013
    #45
    Same lng ba part number ng oil at fuel filter for 2.5 and 3.2 engine? If not can someone tell me the part number for 3.2? I mean for baldwin filters tnx.
    #46
    Quote Originally Posted by ricciboy View Post
    For 3.2l 4m41 you can use bd28 but bd7028 is the recommended baldwin oil filter. Fuel ilter is bf7534. Got mine 830 pesos and the fuel filter at 1250...
    Feb 2013
    #47
    Kcboy thank you for the info
    #48
    May bd7028 daw sa volmax.
    Aug 2003
    #49
    I'm confused with the Baldwin Fuel Filters. Are both BF7535 and BF534 compatible with our pre-2012 Montero and Stradas? I am seeing both part numbers while reading the forums..
    But when I accessed the Baldwin site, OEM 1770A053 is crossed with the BF7535.
    My BD28 I got from a fellow Tsikoteer..
    #50
    Quote Originally Posted by ek2jayvee View Post
    here is your answer.
    2008-2011 monty and strada 2.5 or 3.2 will have no problem fitting bf7535. regarding bf7534, pajero and advie, perfect fit, but on monty and strada, case to case. i for one used 2 pcs of bf7534 and no problem. an officemate and prince777 had fitting issue with it(7534), they had to change to 7535, considering their montys are also 2011 model same as mine. bottom line it is safer to use 7535 on monty
Replacement Oil/Fuel/Air Filters for Strada/Montero Availability
