Results 11 to 20 of 92
- Jan 2013
- 82
February 14th, 2013 08:45 PM #11I know that VIC filters are made in japan. I never said it wasn't. Filtering efficiency is not measured by merely looking at filter media alone. We have a resident oil and filter expert here sir Dvldoc. You can read all about the tests done on lots of filters at remote bypass filtration thread here in tsikot. I have been using vic's before until i found thru research that you can get better protection for your engine using better filters which are lot better than vic. Just because it's made in japan does not mean it's the best, usually is but not always.
Tsikot Member Rank 1
- Jul 2009
- 4,090
February 14th, 2013 10:06 PM #12
February 14th, 2013 10:26 PM #13
Sirs, please advice what is best engine oil, oil filter and atf fluid for gls se TIA
- Mar 2013
- 12
March 24th, 2013 03:49 PM #14Sir if you want OEM filters may mura akong nabilhan. yung kuha ko sa FM kong OIL Filter was only 900Php lang at yung Fuel Filter 1,600 Php. Hindi sya SP (Service Parts) na kulay pula yung kahon. share ko contact number nya 2544730 look for iris
March 24th, 2013 04:04 PM #15
Meron pinagbilhan dati yung kamember ko sa tscp eh, bosch ata yun sa may recto. Mas mura at mas matibay kesa sa oem.
March 24th, 2013 04:19 PM #16
- Mar 2012
- 63
March 26th, 2013 12:52 PM #17
March 26th, 2013 01:02 PM #18
March 26th, 2013 02:14 PM #20
The Corolla Cross's interior, even on the GR variant, doesn't come close to the CX-5 or even the...
All New Toyota Corolla Cross
