Results 51 to 57 of 57
September 11th, 2006 11:33 PM #51
Hindi naman problema iyon kung pantay siya. Yung sakin pina-level ko nga since madalas ako lang ang sakay at medyo mukhang engot yung hitsura kung nakayuko.
Pwede mo pihitin yung torsion bar para dumapa yung harap. Bilangin mo lang kung ilang pihit ang ginawa mo dun sa isang side para ganun din kadami gawin mo sa kabila.
Ito yung article, it's called cranking up the torsion bars. In your case, pabaligtad dapat ang pihit mo ng wrench since you want to crank it down.
http://www.4x4wire.com/mitsubishi/te...s/torsion_bar/
Pareho lang front suspension ng GEN I at GEN II. Don't mind the pictures. Actually, halos pare-pareho lang lahat ng torsion bar suspension. You crank one, you've cranked them all.
- Jun 2004
- 476
September 11th, 2006 11:34 PM #52Maybe that's why RATS recommended that you change the coil springs at the rear. Baka bagsak na. Pero have it double checked para sure. My '99 gen 2.5 with a little over 100k km clocked di pa naman.
While your at it have the setting of your torsion bars checked. Have it re-set to stock settings baka kasi naka crank up siya to begin with. Did you get your rig brand new or second hand?
September 11th, 2006 11:42 PM #53
sabi ng RATS ok pa naman yung coil springs e... We bought it brand new Aug. 99 and have 140k clocked already (grabe no)...
Baka nga when we bought it e naka-crank up na sya by default kasi pantay nga e... We bought it from Diamond Motors Makati before...
Anyway balik na lang kami sa RATS soon... meron pa namang 500km at 5,000km check-up e... pero susulitin ko na yung binayad naming 22 thousand petot para naman masiyahan ako dito...
Bigyan ko kayo ng feedback pag na-drive ko na ulit...
September 12th, 2006 10:23 AM #54
We also have the 99 Pajero medyo pantay sya compare to 2001 up model and sa tingin mas pandak sya. Sabi ng agent namin kasi daw wala ng 4wd option kaya ginawang 4x4 look.
- Jul 2009
- 8
July 10th, 2009 04:46 PM #56
Hi, i'm not familiar with the fieldmaster, but from what i know, there are no shocks in front(leaf spring) only the rear has shocks? Or is that a different model pajero? Anyways, bilstein is a good brand for shocks, i've been using fieldmaster shocks for my montero and it cost about 8t a piece i believe.
October 7th, 2009 03:08 PM #57
