Results 31 to 40 of 64
- Nov 2004
- 115
June 13th, 2005 05:01 PM #32pano kaya ang process ng pag linis nila.. baka kaya DIY??
is it true na dapat nag free-free wheel ung blade sa loob ng turbo? i tried turning mine, medyo matigas na..
- 441
June 13th, 2005 05:33 PM #33yes,sa central diesel,they also offer turbo repair and rebuilding if you have probs with your turbo's.my mga parts sila ng mga turbo's dun.
- Nov 2004
- 115
June 13th, 2005 06:29 PM #34Originally Posted by v22
ano ba reason bakit nag kakaoil sa turbo? ung sakin ang daming langis din!
June 14th, 2005 09:41 AM #35
your turbo is cooled by your engine oil... if that seal starts to leak, oil gets inside the turbo and gets sucked in by the engine... although konti langnaman yun, its enough to make your intake sytem and the turbo dirty, eventually stucks it up...
- Nov 2004
- 115
June 14th, 2005 11:42 AM #36v22 thanks for that..
is it safe to simply remove the turbo and clean it? or may mga mechanism pa dung mahirap i balik?
June 17th, 2005 10:35 PM #37
if your familiar with it, why not.. but if you want a more thorough cleaning job, then it wold be best to leave it to the experts.. they competely dissasemble the insides pa....
June 17th, 2005 10:49 PM #38
For Php 3K to have your turbo serviced is pretty cheap and reasonable.
BTW, do you leave your car to idle after driving? You should let it idle for about 2 minutes to cool down the turbo bearings and change your oil frequently. Turbocharged engines should be changed twice more frequently than a N/A engine.
June 20th, 2005 12:25 PM #39Originally Posted by airshaq20
- Nov 2004
- 115
March 15th, 2006 09:14 AM #40hello again, just like to bring up this topic..
i recently had my pajero calibrated, it cost 9k.. mura na ba? anyways, nawala ung usok ng pajero (as in dramatic) and ung bad smell ng fumes.
but, feeling ko hindi nag bago ung hatak ng sasakyan.. may improvement pero slight lang.. i think baka ung turbo ko kelangan na pa overhaul.. nag canvas ako and sabi sakin dun sa pinag calibratan ko, budget daw mga 5k.. palit daw bearing saka kung ano ano pa.. medyo namamahalan ako eh...
ung MKF ba along blumentrit papuntang chinese general or papuntang abad santos?
Suzuki JIMNY [merged threads]
