Results 21 to 30 of 37
August 8th, 2003 08:14 PM #21
Maki, check your suspension seats. They might be set too soft. It gives the impression of the rear shocks bottoming out, but the shocks bottoming out are the seats'.
How much yung bigay sayo Gas-A-Just? OKs diba?!
- Feb 2003
- 144
August 8th, 2003 09:05 PM #22850 gas adujust... 950 yung excel g for rear, kasi daw mas mahaba yun?!!?!??! heheheh bakit ganun!? =) ok ride.. wala ako marereklamo..
pare anu yung suspension seat(s)?
August 8th, 2003 09:24 PM #23
Tama lang ang presyo bro! :D
Its possible na mas mahal talaga yung rears. Yup, theyre bigger!
Buti nga sa auto natin, mura lang ang shocks! Sa sedans, mga 1200 pataas each!
Pare yung front seats natin may shocks yan!!!
Tignan mo upuan mo, sa harap nun (between your legs pag nakaupo ka.... hindi yung yagbols mo ha :D ), mayroon adjustment dapat. Its a knob na circular, with which you can soften/harden the seat suspension.
If you try turning it, makikita mo gumagalaw yung may nakalagay na soft/hard.
- Feb 2003
- 144
August 9th, 2003 10:08 AM #24ahhhhhhh oki oki yun pala...kala ko ano ibang seat eh...yah meron nga...parang hydraulic or pneumatic type...yun..but i dont thinks that was what i felt bottoming out... yung rear tlga eh.. kasi ask ko 2nd opinion ng kptid ko...sbi daw niya parnag bumaba din yung likod..=( kasi yung tinanggal na old shock ko mas matigas sa new one pero yung luma matagal na umangat when you compress it...(test namin before kinabit yung bago)
bigat kasi ng rear ko eh..3dr na paj pero yung rear ko puno ng sounds..as in puno na...laki box eh.. wala na nga malagay eh,, =(
August 9th, 2003 10:21 AM #25
IMO lang your old shock is also gas, since you mentioned that it does not up as fast as the new one. but it does not mean na busted na ito, signs ng busted gas shocks is when you depress it it does not hold. maybe the rear shocks they put in your pajero is not intended for the pajero, or your rear springs are sagging already because of the sound set up.
- Feb 2003
- 144
August 9th, 2003 12:02 PM #26got it at motorix.. direct bolt on naman eh =) yah baka nga springs are sagging...thanks man
August 9th, 2003 12:43 PM #28
question???
so di na working yung ride adjustment ng pajero pag nag palit ng shocks... yung S/M/H.
August 9th, 2003 12:57 PM #30
S/M/H does not adjust ride height. It only adjusts the stiffness of the shock.
