Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
    mahal pala ng airfilter ng pajero 1,800.
    i just got mine as a replace ment wla pa 300 pesos. palitan ko na lang every 5,000 kms....so more or less 3 years na bago mo mabawi yung 1,800...sulit na din.
    Nov 2004
    kcboy / nugundam - it's 3.5L V6 Gas. yes gusto ko nga palitan yung corner lights ko (amber siya ngayon).. may nakita ako sa ebay na clear corners (medyo dark yung pagka clear niya) from HK. it cost $70 shipped to california. if u guys know places where i could have my dad buy parts for me let me know. lalo na kung around QC. salamat bros.
    so most pajero's in pinas are diesel? or meron din gas model? i never really thought about that... 92 gti gallant kasi auto ko dati my dad has the 93 montero.. diesel siya.
    ngayon lang ako nag shift to montero.. i used to drive a jeep wrangler. tagal ko na talaga naghahanap ng montero dito.. between 98 to 2000 yung type ko. my mom in law drives a 2002 montero.. ganda features and all that pero di ko gusto yung body type. last july ko lang nabili yung montero ko.. from a private seller (1st owner siya). i bought it for $8500. and has 70k miles on it. 75% freeway miles. ayos na rin.
    magkano ba ang ave cost ng gen 2.5 montero dyan today?
    Jun 2005
    Sir street&strip, i got mine from Hahn in Shangrila.
    Sir trickster, i believe meron especially sa states. I tried looking for one but the dealer along e rodriguez (forgot the name), only had the oval type. my local paj needs the round type so I just modified one by making a hole for the bolt. I really think the K&N filter does a good job of filtering because after 6,000 km, it was really very dirty. One side had thick deposits already. Parang putik na and I have not seen something like this with the orig P1,800 pesos filter. Hindi ako nag o offroad, puro city driving kaya inggit nga ako kay KC Boy.
    Jun 2005
    Sir Hayward, this is what I did. I bought a K&N filter (will post exact model number next time) which had the same height and inner hole diameter as the orig paper filter from Hahn in Shangrila. The orig paper filter is fixed in place by a bolt, di ba? The K&N filter has no hole for the bolt so I requested the staff of Hahn to drill one for me. When I bolted it in place, ok naman ang fit kasi pareho nga ang important dimensions. The problem was the bolt pressed and deformed the rubber top of the K&N filter when it was tightened hard. I remedied this by cutting the top of a medium sized fruit cocktail tin can and drilled a hole again for the bolt. Now the bolt presses on the tin can top and not on the soft rubber. Hope this helps.
    555 for idler arm/pitman arm/ball joints/tie rod ends/upper arm bushings
    exedy for clutch disc & pressure plate
    k&n (more of an after-market replacement) for air filter
    seiken for brake master cylinder
    vic for oil filter
    KYB gas shocks for suspension struts
    bendix for brake pads
    skf for wheel bearings
    dobbinson for rear coil springs
    docvic,
    sma ka sa amin kung offroad lalo na pag light lang para d ka matakot agad.
    trickster,
    most of the pajeros here na local are diesel. imported yungmga gas . hard to find yung 3.5 gas. top of the line na yan. am sure dami dito willing to trade your signal lights with our local ones.
    Nov 2004
    sige i'll think about swapping my corner lights.
    trade tayo trickster. :D
    merong ganyang parts sa stores like el dorado and atco (mitsu OEM parts suppliers)
    Nov 2004
    nugundam - pag di nakahanap erpats ko soon i'll let u know.
    salamat.
    regarding dun sa air filter. magandang brand for disposables is purolator. K&N pa rin talaga pinaka worth it. pansin ko mas matagal rin dumumi yung langis.
    kung mataas na mileage ng pajero niyo. try niyo auto rx. gumanda yung takbo and better mileage for my ride. di ko lang sure kung pwede siya for diesel engines.
    sure trickster :D
    that auto rx seems impressive. i'll try to ask them if it'll be okay for diesel engines as well.
Pajero Orig budget replacement parts.....
