Results 11 to 20 of 31
February 4th, 2003 04:12 PM #11
4L is twice the power at half the speed. Ok sana ito, however, hindi liliko ang Pajero mo dahil magkakaroon ng 'binding' phenomena.
Mahirap magsabi kung may problema ang Pajero mo dahil talagang mabagal sa akyatan iyan. A Kia Pride will run rings around you. Baka naman hindi ka lang sanay sa bagal ng Pajero.
Ungas,
Hindi ba GEN I ang Pajero ni El? Walang center diff yun. Direct drive ang x-case niya.
February 4th, 2003 04:44 PM #12
Ahehe, wala ba? Parang nakita ko kasi yung kay happiman meron yata. My mind must have dozed off the last time I saw his rig. :D
February 4th, 2003 05:01 PM #13
El Loco:::are you starting from a cold start? If you are hehe ganyan talaga ang 4d56. Try to give it time to warm up. Kahit gasoline engine pag cold iba ang performance. And do not use any of your 4x gear when going up that basement. Did you try transferring to the rooftop parking? :mrgreen:
4x4ph.com
- 695
February 4th, 2003 05:22 PM #14mag-reverse ka nalang paakyat para walang problema :mrgreen:
aheeheehee!
- Nov 2002
- 38
February 4th, 2003 05:25 PM #15Originally Posted by afrasay
tried it sa 1st gear na walang bwelo hirap talaga..
so ginagawa ko..ikot muna ako parking..kuha ng bwelo while in
1st gear then pag malapit na pataas ..2nd gear na ko...
ok lang ba yon..it wouldn't strain the engine..
thanks
4x4ph.com
- 695
February 4th, 2003 06:07 PM #17
4wd won't really be of much help in that case i think... hindi naman kulang yung traction, what you need is more power
February 4th, 2003 06:26 PM #18
sir baka kailangan mong pa check makina mo baka kailangan ng overhaul,kc yung gen 1 namin na 91 hirap ding umakyat,nung tiningnan yung makina dami ng tagas ng langis
February 4th, 2003 07:11 PM #19Originally Posted by El Loco
Give the engine at least 3 to 5 minutes to warm up. Malakas ang 4D56, tested ko na yan, sa L300 VV nga lang. Palagay ko di maganda yung mag change gear ka while going up the parking, baka lalong mabitin yung sasakyan at mag stall ka pa. Better stay on 1st gear. Check your air filter too :P
