Results 11 to 14 of 14
April 29th, 2005 09:29 AM #11
ARB,
Talaga, di dapat pa adjust din TB para pantay. Kaya ba maghapon, saka saan lugar ang shop.Pareho lang ba OME saka ARB? Gusto ko kasi pag dating sa off road eh medyo smooth pa rin at di matalbog, then sa high way eh parang chedeng ang ride, meron b nun?
- Feb 2003
- 144
April 29th, 2005 11:54 AM #12Originally Posted by paj4x4
actually the first thing i did was install the monroe shocks(stock height). then it bottoms out, so i adjusted the TB's, less bottoming out, but better/softer ride.
question lang diba pag nag adjust ng tb to get more height, ang nababawasan is yung droop? like when u jack the car up by the chassis, konti lang ang "Droop" ng gulong kasi nga tumatama na agad sa bumpstop. the problem im having is that pag nag speed humps ako, tapos pag bagsak ng car tsaka magbobottom out (downward movement) not when pataas =( sori labo ako magexplain.. heheheh
im pretty sure it was the same length, but softer or easier to compress. kasi the KYB''s GAJ that i took out was still in good condition. tapos we had the opportunity to test/compress the socks by hand to test which is softer.
overall we tried the KYB GAJ, Monroe matic plus and KYB Excel G's, this is the order from hardest to easiest to compress (by hand), but the diff between the KYB GAJ and monro matic plus was not that big, (but evident) as compared to the monro maticplus and the KYB Excel G's, wherein the excel G's could be compressed to the groun by just using one hand...
April 29th, 2005 10:26 PM #13
dab - its hard to get that merc ride with a leaf sprung suspended vehicle, close maybe but we cannot get both worlds. but it in my case I can attest to the ride quality compard to stock and compared to other isuzu pick-ups at that. I before had inverted rear leafs and the ride was better than stock then i changed to OME leafs and it was better than the inverted stock leaf ride. yes adjustment of the front TB's but not too much the stance should be front lower a bit. OME is under ARB. You can get your OME's there in manila from RATS 4x4.
May 4th, 2005 09:13 AM #14
ARB,
Thanks Bro for the input, I was about to upgrade under chassis and aiconditioning instead of painting which will cost me 30K or more na sasama pa loob ko pag nagasgasan.
