Page 872 of 1458 FirstFirst ... 772822862868869870871872873874875876882922972 ... LastLast
Results 8,711 to 8,720 of 14580
    Jun 2007
    #8711
    Ooops, double post.
    Jun 2007
    #8712
    Quote Originally Posted by marchelju View Post
    sirs,
    tanong ko lang po kung puede ba ma lagyan ng parang plate ( anong tawag dun, sorry di ko alam kc ang term)under sa front bumper ng strada kagaya nung sa montero sport? at kung puede saan po maka bili, dito po ako sa gensan.
    thanks a lot.
    Hello marchelju. Skid plate or bash plate po ang tawag dun.
    Para makasiguro ka, check out this link: TSCP Strada Mods You will also see modifications of the strada courtesy of the Strada club members.
    #8713
    thanks a lot sir ooba99.sana maka kita ako dito sa area namin na nag bebenta ng ganito.
    Jun 2008
    #8714
    There will be shipment next week if you want na mag pasabay just pm me or email me at normandysamson*yahoo.com with your contact info thank's po.
    May 2008
    #8715
    Hi,
    I am from monty thread. Do your unit has similar issue on starting engine that has a thump sound (tranny hitting the chasis).?
    http://tsikot.yehey.com/forums/showt...t=58535&page=2
    Dec 2007
    #8716
    Hi,
    welcome to the strada thread sir. wala naman lumabas na ganyang issue sa mga strada namin.
    question lang po... is this your first diesel vehicle? kasi kung nasanay ka na sa gasoline fed na sedans, ibang-iba talaga ang feeling in terms of vibrations sa makina since kahit crdi na, diesel pa rin ang fuel natin. pero kung excessive vibrations and thumping sound na... and kung mas grabe pa sa mga old school diesel engines, may mali na talaga sa unit mo and dapat ma-check na yan ng dealer mo. good luck!
    #8717
    mga sirs, im planning of buying a pick up. kindly help me of choosing one between strada and navara.........
    wat r the pros of owning strada? is it better than navara?
    wat are the edge of owning strada rather than the famous navara?
    advance thank you on your opinions guys.TIA
    Dec 2007
    #8718
    Quote Originally Posted by DonCuadro View Post
    i could not give an objective opinion since I havent driven a navara yet...
    pero here are the opinions of those who had the opportunity to compare the two vehicles...
    a. truck bed of the navara is bigger
    b. cabin space of the strada is roomier
    c. acceleration of navara is quicker but top speed, depende na yun sa dibdib ng driver, hehe
    d. more expensive ang navara
    e. sedan like suspension of strada is better
    f. the strada has "a club that rocks" hehe
    over all, nasa end user kung ano ang better vehicle... pero since strada thread ito... I suggest go for the strada
    Jun 2007
    #8719
    [SIZE=4]f. the strada has "a club that rocks" hehe[/SIZE]
    yan yung pamatay dyan Sir Tp, hahaha!
    dagdag ko lang po.
    Curves
    Navara-its too boxy
    Strada- its too ***y
    Height
    Navara- Very low ground clearance for a pickup
    Strada- Very appropriate ground clearance for a pickup
    In terms of the engine naman po.
    "from what I heard" the navara is really fast. but I think sa top speed it somewhat lacks daw.. With regards to the strada naman what I've confirmed from a friend of mine (not a member of the club but drives a strada 2.5GLX) he was able to reach a top speed of 190kph
    and to help you more sir doncuadro there is a lot of automotive magazines out there that has done several revues on both pickups so maybe you could source out some of those back issues....
    still in the end as what everybody else says, you should choose the vehicle that fits you best.
    But I would definitely recommend the Strada....
    May 2007
    #8720
    *locoroco777- perhaps you might want to recruit your friend to join us onboard, too.
    a club that rocks? beyond reasonable doubt, yes indeed. :rockon::rockon:
