Results 7,371 to 7,380 of 14580
November 1st, 2008 01:38 PM #7371
- Jan 2008
- 4,726
November 1st, 2008 02:40 PM #7372
electronically operated na din po ba ang accelerator pedal ng new strada??
although wala po ako strada but i think this case happens din sa ibang CRDi engines with manual transmission..
kung electronic na din same po sa kia carens CRDi eh normal po talaga yung naarangkada ng konti yung sasakyan when downshifting.. i don't think its the "low end torque" it just happens the the engine is preventing itself from stalling when you release the clutch (may sensor po kasi sa clutch once it is released) the engine ECU increases the RPM kaya parang naarangkada pa...
try nyo po sa 1st gear release nyo yung clutch without stepping on the gas pedal.. pag malapit na fully released yung clutch the engine RPM will increase, then aandar yung vehicle without the engine struggling unlike sa conventional diesel engine..
- May 2008
- 664
November 1st, 2008 07:16 PM #7373hi sir! of course ma convinve ka talaga kasi strada forums ito hehe but what im trying to say is im very haappy with my choice despite some minor problems which can be fixed naman and thanks sa strada club for that. FC kosa GLX is around 10-12 nag full tank ako the other day para mas ma computre ko accurately.will update nalang if anon talaga FC.
November 2nd, 2008 12:40 AM #7374
Mga bro just meet up with bro ThePatriach late afternoon today unfortunately late na masyado kaya hindi na kami na kapunta sa shop's my apologies po, nag ka taon din na sundays most of the shop's are close. Bawi na lang po ako sa next bro na punta dito.
November 2nd, 2008 12:53 PM #7375
Low end torque, I think is not a bad characteristic at all for me and from what I heard and read.
I only used the term because I think that what best describes the matter that happened to me and to you I supposed when were still adjusting on driving our stradaalthough Im not sure if I've used the term correctly
happy driving!
November 2nd, 2008 01:21 PM #7376
Throttle (RPM) sticking or revving-up even the accelator is fully released?
sometimes, you almost bumped the car in front of you becoz you're expecting the truck to decelerate but instead it surges forward? hehehe..
sometimes you feel that somebody might think "mabigat and paa mo" because the RPM is sticking or increasing while you step on the clutch to change gears...
- May 2008
- 664
November 2nd, 2008 05:34 PM #7377mga fellow BOSBs meron na bang projector headlights para sa strada natin? para ok na e HID
November 2nd, 2008 06:00 PM #7378
In addition;
anybody from strada owner experience changing their fog lights with HID bulbs. any modification in the housing or assemble or only the bulb was replace. thanks in advance.
- May 2008
- 664
November 2nd, 2008 06:04 PM #7379
November 2nd, 2008 07:49 PM #7380
strada headlights are the basic H4 lights. if you plan on changing the bulbs, madami off the shelf kasi standard bulb configuration naman ang H4. just make sure you dont get the 90/100 and above bulbs, baka hindi kayanin ng wires, kasi medyo maliit ang wires na ginamit nila. you can extend get the high output bulbs which would dish out 100/110 even if your using 55/60 (parang baliktad yata ang mga wattage ko? oh well) or you can opt to install HID's which a lot of our brothers here have already opted to do, but do remember that going HID WILL VOID YOUR ELECTRICAL WARANTY!!!
Nakakakilabot yung bagong srps taking into consideration na mag-10 years na ang current model neto.
All New Toyota Hilux
