Results 6,051 to 6,060 of 9388
August 24th, 2009 10:46 AM #6051
meron na po bang nagpatanggal/palit ng center console ng 4.2 GLS variant nila to give way fo the 1 din dvd monitor? kung mern saan po kayo nagpagawa? is this possible sa mitsu dealers? and post some pics if ever. Thank you!
- May 2008
- 290
August 24th, 2009 11:16 AM #6052
August 24th, 2009 11:34 AM #6053
- Jan 2009
- 108
August 24th, 2009 01:36 PM #6054I'll add to this, aside from what NTYCE, mentioned on tinkering with your ecu. Installign a blow off valve is not as easy as 123. You have to change couple of pipes in the engine bay area where the turbine is located. Also im pretty sure why you want to install a blow off valve, maybe to achieve that "psssshhh" sound while speeding. No you cannot achive or there is no guarantee that you will achieve the blow off sound. Diesel engines are way different in characteristics than gas powered engines. This discussion is quite a long one and you may search it in google to get a better knowledge of it. Hope this helps sir.
August 24th, 2009 02:24 PM #6055
- May 2009
- 37
- Jun 2005
- 247
August 24th, 2009 03:19 PM #6057
August 24th, 2009 03:38 PM #6058
hehehe iba ang accessories dito ng monty kaysa sa atin kasi nga europe ang spec niya mga heater sa seat at sa loob. kasi nga kapag winter kailangan mo ang heater at para di mag mist ang windshield mo subukan kong mag post ng monty dito. yung translation ng isang post medyo may kulang kasi sa mga online kung minsan di niya recognize yung ibang work kasi ng cyrullic to latin . yung luc duon ibig sabihin noon eh sunroof
kasi unang labas eh pajero sports na pick up tapos yung isa Nativa naman yung close van talaga siya dito sa europe na sinundan nga ng Montero sa Pinas, ang Montero eh Chrysler kaya identical ang itsura nila yung ibang parts eh pwede mong gamitin vice versa pwera lang ang mga ecm dahil mag kaiba ang spec na duon. sana nga ng i design nila yung monty sa pinas eh nilagyan nila ng heater para pag na ulan eh malinaw ang windshield mo hehehe . yun eh comment ko lang
ciao !
August 24th, 2009 04:14 PM #6059
Sir RevD,
I'm not sure if I understand your question. Is the "1-din DVD player and a 1-din Monitor" separate? 1-din each?
I'm asking because I'm curious if you will still be able to use the multi-info display? Placing the monitor below the multi info display and replacing the stock HU with the other HU. My aunt might get an SE variant and planning to place a 2-din HU, if my question is possible, I might suggest that modification route also.
Naalala ko iyong 2013 SJ Forester ng relative namin. FMC change siya ng time na nakuha sa casa. ...
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
