Results 11 to 17 of 17
- Mar 2005
- 211
March 14th, 2005 10:39 AM #12
Hi Jay101 and rhops, Im also from Cavite I know a very reliable mechanic here in our place na nag se service sa ride ko (Pajero Subic). PM to get his number and add.
- Dec 2002
- 2,335
March 14th, 2005 01:45 PM #13if you have the cash you can do this all in one, walang hassle sa denso sa banawe, they charge 3.5K for the complete drain using a machine including labor and atf. use an atf na spec ng oto mo. dexrton 2 or 3 yan. not all gets drained if you do it manually as some are inside the torque converter. filters, you can clean it and possible din na palitan if you can get the part. basta mekaniko kaya yan. you have to replace the gaskets though or gasket maker. iba iba suggestion ng mga manufacturer, iba 20k iba 30k before changing. sabi nga ni pk its up to you if you want to indulge.
- Feb 2004
- 39
March 15th, 2005 10:24 PM #15mga sir san kaya ako makabibili ng dextron 2? yung din kasi sabi sa akin ng freind ko.
thanks
March 16th, 2005 12:11 AM #16
The GEN II a/t will take the usual ATF sold in local service stations (e.g. Shell, Caltex, Petron). The a/t used is not very sophisticated. It will actually take almost anything. It is also very robust and can withstand a pretty good beating.
- Feb 2004
- 39
March 16th, 2005 11:41 AM #17sir OTEP thanks as advice. I'll have my ATF change this week.
1 more question. masama bang pang hila ng kotse yung mga naka automatic. ginamit ko kasi yung paje ko para hatakin yung kotse ng officemate ko at a distance na 13km.
One feature they should incorporate in EVs is speed limiting based on the keyfob you hand over to...
