Results 11 to 14 of 14
April 30th, 2003 02:33 PM #12
breakthrough guys. had d car inspected by a radiator shop. it turns out na stuck-up yung thermostat nya kaya d maganda yung circulation sa radiator.nung napalitan na yung thermostat, ok na yung flow.d ko na pnagalaw yung water pump kac napalitan na rin yun dati e. kaya pala dati, pag speeds above 100kph, (110 or 120 kph) mas tumataas yung temp, umaabot sa kalahati e. sana d hunt stops here para mas makamura.yung filters saka ko na intindihin kac nga process of elimination to :lol:
Tsikot Member Rank 3
- Dec 2002
- 636
April 30th, 2003 07:01 PM #13That's good to hear. Did you use distilled water with coolant for refill?
Suggest you check the radiator fan if it's the clutch fan type. The silicon within gets less viscous over time which means the fan won't "bite" when the engine gets hot.
April 30th, 2003 11:29 PM #14
yup, filled it up w distilled water, knda anticipated it.will take d car on a long ride dis wkend 2 find out if there's any difference. tnx agen :D
We previously supported Tapatalk for Google Play and iOS store, but both are unsupported right now....
tapatalk smart phone application.
