Page 318 of 324 FirstFirst ... 218268308314315316317318319320321322 ... LastLast
Results 3,171 to 3,180 of 3240
    #3171
    this isofix thing piqued my interest. will check my cars for them nga. mahirap lang daw hanapin minsan kasi nakabaon beneath the rear seats
    anyhow, baa ito makatulong:
    https://www.topgear.com.ph/features/...d-safety-seats
    #3172
    anyone here know how to change the burnt out bulb of the glove compartment?
    Aug 2018
    #3173
    mga ka monty, saan po kaya may mahusay na mitsubishi pag dating sa service? specially sa aircon..laguna po location ko.. thanks for the advice..
    ano po kayang possible problem, if nasa 20 degrees C ang temp ko pataas, mainit na kaagad ang labas ng hangin (parang heater) sa 19 degrees lang sha nalamig.. ang huling ginawa ay nag jumpstart bago naging ganun.. montero 2015 gls v po ang unit ko.. thanks for the help..
    Aug 2018
    #3174
    Quote Originally Posted by Jojo04 View Post
    Pa calibrate or check thermosrar nyan
    #3175
    salamat Zix Performance
    mtf lang pala ang problema. ang masaklap, casa pa ang naglagay nung maling langis... tested for long drive, p. guevarra to tagaytay w/ stop over in las pinas... wala nang sabit sa 2nd gear.
    Quote Originally Posted by 99gil99 View Post
    ano po kaya ang prob sa m/t na mahirap magchange gear sa 2nd (down or up)?
    nangyari to after ng change tf nung 25k PMS. ilan beses ko na inireklamo sa casa & ang reco nila palitan yung pressure palte, clutch disc, etc.
    btw, 35k palang mileage ng monty ko... so 10k na akong hirap sa change gear
    ty sa sasagot
    Sir, good to hear everything is working fine now.... however, have you reported this incident sa manager sa casa? They should cover the repair done to your vehicle since sila yung may mali... casa pa naman sila, they should know better...
    Jun 2018
    #3177
    What casa is this? So incompetent. You should complain. Bring it to the attention of their customer service, at the very least.
    Feb 2015
    #3178
    Anyone know how you can exit the PMS warning display of a 2017 Montero? It just overrides all other displays.
    Aug 2017
    #3179
    Quote Originally Posted by Jolly Rogers View Post
    What exact variance bro.
    1. Make sure your monty is switch off
    2. Press the select button until you find the pms [emoji373] logo.
    3. Long press the select button 3 to 5 sec. Or until the pms [emoji373] logo blinks and beep once.
    4. Then press the enter button to reset pms reminder.
    You cannot reset pms reminder sa HU bro even you put code likes 3280 etc that you've seen in youtube. It only remove the pms [emoji373] logo and when you switch off your engine at restart it again it will pop out once again.
    Sent from my iPhone X using Tapatalk
    Feb 2015
    #3180
    Quote Originally Posted by montro View Post
    Thanks for your reply. I have the GLS.
    The PMS warning sign appears on the HU. If you press exit it comes back a few minutes later or, as is often the case, displays the Car Info with the small PMS warning. Ive read somewhere too that if you long press the display and input code 3820 it will exit. Ill try it this weekend.
    Thanks!
Montero Sport PMS Thread
