Page 306 of 324 FirstFirst ... 206256296302303304305306307308309310316 ... LastLast
Results 3,051 to 3,060 of 3240
    #3051
    15KKm PMS - P7.2K
    Practically oil change (semi synthetic)...
    Waived recommended cleaning of EGR and wheel alignment
    Condenser fan replaced under warranty (mabagal daw ang ikot - i have not noticed it,- so maybe caught through a diagnostic test).....
    Mar 2005
    #3052
    Peeps anybody tried using Blue Chem CRDI fuel additive? pros and cons?
    Sep 2016
    #3053
    What's the biggest tire size that can be installed in Montero without any lift/mods?
    Sent from my ONEPLUS A3003 using Tsikot Forums mobile app
    Nov 2014
    #3054
    Quote Originally Posted by Danilog View Post
    If you are using the OEM rims, you can use 265/70/17, but if you are using an after market rims with less than +30 offset, stick to 265/65/17. If you are using 20" rims, 265/50/20 will do.
    Sep 2016
    #3055
    Am using stock rims. Gusto lang sana lakihan gulong while maintaining stock. Thanks.
    #3056
    ^ ganda nga tingnan iyong mga slightly malalaki gulong pero stock rims na naka a/t tires at mas lalo na naka mud tires. 😍
    Usong uso sa australia at russia ata iyong ganyang setup sa mga 2nd gen na monty aka challengers sa down under at pajero sport naman sa russia at ibang bansa. Bangis eh! 👌
    when you look into the abyss, the abyss looks into you
    Feb 2006
    #3057
    Meron po ba naka-eperience sainyo na bigla na lang hindi nag-accelerate while in drive mode? I experiencing this yesterday while I drove my montero 2011 matic in slow traffic but when I put it back to nuetral and back to drive again ok na ulit sya . Still observing it po if mauulit. Do you have any idea kung ano problema kaya? Salamat!
    #3058
    baka inhibitor switch mo may problema. napalitan na ba iyang part na iyan before?
    if you're from manila, check w/ bro zix to be sure
    Feb 2006
    #3059
    Hindi pa po napapalitan almost nasa 60kms na ODO, ganun po ba symtoms pag-inhibitor switch may problema nawawala acceleration/rev nya on DRIVE mode need pa ibalik sa nuetral then back to Drive mode? Salamat po!
    Oct 2017
    #3060
    [QUOTE=HugoThor;2886585][QUOTE=monty_GTV;2886347]i have not use yokohama geolandar. you may want to check out gt savero at+, i'm on my second set na, so far ok naman...
    Sir, planning to have my EGR blanked, then bka try din K&N filter ska OCC. Newbie question lang, ano po advantage? Ska magkano din kaya budget na need allocate?
Montero Sport PMS Thread
