Page 269 of 324 FirstFirst ... 169219259265266267268269270271272273279319 ... LastLast
Results 2,681 to 2,690 of 3240
    Jul 2016
    #2681
    Mga sir, san kaya okay na casa ng union or peak? 1k pms na kasi ako next saturday. Papaschedule ko na sana. San ba yung okay ang service at walang mandurugas ng pyesa? Yung kita payi sana ang kotche habang ginagawa. Thanks mga sir.
    Nov 2007
    #2682
    Quote Originally Posted by Cons29 View Post
    question po. sa montero (or mitsu) po ba, sa pms, kilometers lang ang usapan? hindi 5k or 3 months whichever comes first? say naka 5k ako pero in 6 months, ok lang yun? yung iba kasi parang strict na 3 months, masyado magastos esp kung di masyado gamit ung car. Salamat po sa sasagot
    Mga Sir, sabi sa page 163 — PMS is primarily based on km and not duration. Kaso 2014 pa itong info. Accurate pa rin ba sya? Planning to get a unit but a bit concerned sa cost if I need PMS every 3 months - top up 3 months and change oil 6 months. On average, I only hit 5k every 7 months. If purely based on km ang pms requirement then I don't have to worry about the cost. Thanks.
    #2683
    Quote Originally Posted by katsupoy View Post
    ^ Thanks
    Ano ginamit nyo pang atf pag dialysis na?pwede ba ung mumurahin lang then sa huli na yung transmax?medyo nagtitipid e tsaka masasayang lang din kasi medyo mahal transmax kung itatapon lang
    Last na question,nirecommend din sa akin na pwede linisin nalang atf filter.pero parang mali siya.tama ba? Ano type po yung filter na un?foam ba o parang strainer lang?
    ATF dialysis replaces the 40% ATF located within the torque converter. Its not a necessity to have your ATF undergo dialysis as regular ATF and ATF Filter replacement every 40,000 kms is adequate.
    #2684
    Quote Originally Posted by Allan023 View Post
    Just have your engine oil and oil filter changed at least every six months. You can use regular 15w-40 API CF mineral oil for minimal costs.
    #2685
    Makiki ride na din sa tanong boss. Nagpalit na kasi ako nung 60tkms ko pero hindi ako nag palit ng filter. Kelangan ba talaga nun kahit nagpa dialysis ako? Tsaka ilan liters magagamit sa dialysis? Pwede din ba ordinary oil gamitin sa dialysis tapos transmax gamitin ko sa huli? Thanks
    Have the ATF filter replaced on your succeeding ATF changes to prolong the life of your A/T. Use only ATF that meets the required Mitsubishi SP III rating. Using regular ATF Dexron III will damage your A/T. ATF dialysis will consume a few liters more than the max capacity of your A/T. See your owners manual for ATF max capacity rating. Mixing ATF is also not advised.
    #2686
    Up ko lang tanong ko. Nakausap ko na ung fronte,pwede hindi na daw i dialysis kung papalitan na tranny filter. Tama ba un?
    Tsaka pwede ordinary atf ipapaikot sa dialysis bago ung transmax?
    Use only the same ATF during dialysis.
    #2687
    Quote Originally Posted by SeQ View Post
    Mga sir, tanong ko lang kung ano kailangang ipagawa sa 45k PMS. Balak ko kasi hindi ipagawa sa Casa. Salamat!
    Specific service jobs for 45,000 kms can be found in your service manual.
    #2688
    Quote Originally Posted by kid_curt View Post
    Mga master's san ba ako makakamura ng change oil pms 22k mileage.
    18,000 ang qoute sakin sa oliveros kasama daw tune up?
    TIA
    Cheapest is to have it done at your suking gas station using regular 15W-40 API CI-4 mineral oil, Vic oil filter plus 150 pesos labor charge at 8-10,000 km intervals if your vehicle is out of warranty. If still under warranty just use regular Mitsubishi 15W-40 mineral oil on 5,000 km oil changes.
    #2689
    may nagpalit na dito ng atf filter ng '12 gls-v? magkano ang filter?
    ATF Filter costs 2,000+ pesos sa casa.
    #2690
    ^ kailangan ba sabay ang pag palit ng atf filter sa pagpalit ng atf?
    To prolong the life of your A/T its advisable to have the ATF filter replaced together with your ATF.
Montero Sport PMS Thread
