Results 191 to 200 of 209
- Nov 2019
- 962
June 9th, 2022 12:23 PM #191Sa sinalihan kong FB group, eto yung napansin ko na mga postings nila:
1. FC is not good for Xpander Cross (hanggang 9km/L lang for 80-90 speed). Not sure though how much FC if lampas 100 na speed mo.
2. Madaling kalawangin exhaust pipe.
3. Madaling ma lowbat battery, most users hindi aware na nakakashorten pala battery life if lagi naka accessory mode during push button. Most of them akala nila the correct way of using push start button is to start from accessory mode first before stepping on a brake pedal.
4. Some members has rear shocks defect already even if ODO is still 15km.
5. Fuel pump issue (for early released units) - there was a recall already and I assume affected units are already taken cared of by CASA. Unless walang paki si owner sa unit.
Other than that, walang major issue so far.
June 9th, 2022 06:04 PM #192
- Jun 2015
- 2,751
June 9th, 2022 06:11 PM #193How can switching to ACC before starting drain the battery? Do they leave the A/C on when they shut off the engine?
Anyways, I remember may kumalat sa socmed na mali daw yung derecho start sa push button at dapat daw idaan muna sa ACC. Marami siguro sa kanila ang naniwala.
- 52,698
June 9th, 2022 06:48 PM #194
- Sep 2010
- 2,859
June 9th, 2022 06:56 PM #195
- Nov 2019
- 962
June 9th, 2022 07:12 PM #1961 yr+ lang tinagal battery nung kakilala kong user nito.
I asked him paano siya mag start, eto daw yung style niya.
I on muna to ACC mode, then push again with brake pedal para mag start.
Probably when ACC mode is on, high chance that he will turn ON the AC before ma start engine.
Malaki chance eto yung scenario if naka ACC mode tapos walang know how user sa auto niya.
1 yr lang din warranty ng Mitsu for the battery so hindi niya na claim before mag expire battery niya.
Maybe depende din sa user but this should not be a major issue, especially if you replace the stock battery to a higher end brands like amaron.
- Nov 2019
- 962
June 9th, 2022 07:23 PM #197
- Jun 2011
- 1,077
June 9th, 2022 10:39 PM #1988~10kpl FC sa city depende sa trapik.
Iyong oem battery ng isa less than 2 years, dahil bihira nagamit ng pandemic.
Iyong oem battery ng isa pang unit more than 3 years. Mas regular ang gamit nito. Kung hindi lang nag crack ang casing at sumingaw ng acid, hindi pa sana papalitan battery. Malakas pa mag start.
Nagustuhan ko dito ay okay ang NVH, malambot upuan at suspension para sa isang MPV.
June 10th, 2022 07:47 AM #199
September 21st, 2022 02:04 AM #200
ano pala iyong symptoms nung fuel pump issues daw ng xpander (pero solved na daw siya) ?
Latest mileage:
