Results 111 to 120 of 14348
- Mar 2006
- 39
August 5th, 2010 12:21 AM #112
sayang yung DIY mo, it came in not so good timing...
http://www.gmanews.tv/largevideo/lat...rs-also-banned
ingat na lang baka harangin ka.
- Mar 2010
- 30
August 5th, 2010 12:22 AM #113re: fusebox diagram
* blue_gambit - yup, ganyan na ganyan yung fusebox, hindi ko maintindihan
kung ano yung designated parts/circuits nung mga fuse..
* monty - ayun! thanks! kopyahin ko nalang for reference
August 5th, 2010 12:36 AM #114
eto translation paps as per my japanese seller:
phpto1 cover only.
VO spare spare
10A (rear heater) 15A (door lock) 20A (dual aircon)
15A ACC socket 10A 4WD 10A 4speed automatic
20A (sun roof) 10A (power windw) 10A heater rilay
25A heater 15A wiper 10A radio
15A stop 10A horm 15A cigar
15A back up 10A meter
10A clock,room 10A turn up rilay
&nbs p; ACC
&nbs p; heater
Adjust mo na lang alignment pero basically yan yun
August 5th, 2010 07:31 AM #115
thanks sir monty
thanks sir jacorb for warning.. hehe
sana wala manghuli.. hehe so far... wala pa naman humaharang sakin.. and if meron man humarang.. ok lang.. since its still not working po.. hehe
August 7th, 2010 11:42 PM #116
monty, I think pwede makalas, tanggalin mo lang blower motor behind the glove compartment. pag tanggalin mo yung stopper ng glove compartment machecheck mo na siya kung durog na yung foam.
heto bro may pic ako dati, yung nasa passenger side na may white square na grill, pag ginalaw mo recirculate lever gagalaw yung doors, dapat both sides may foam yung doors. 2 doors with 4 faces.
weekend DIY ko, share ko lang, nilinis ko yung internals ng intercooler ko, nilagyan ko ng 1 liter of gasoline then inalog alog ko, swing ko siya from left to right hanggang mapagod ako, nakakatuwa gawin to, trust me nung pumasok yung gas clear blue siya, ayun pag labas parang coke, nung pag kabalik ko di ko muna kinabit yung hose papasok sa intake manifold para mabugahan at matuyo ng todo yung loob,.
nung nakalas ko intercooler I also tested my glowplugs, buhay pa lahat, 5 years and still going, also had my emission test, .5 score ko. not bad :grin
August 7th, 2010 11:54 PM #117
PB, do I need a specialist for cleaning the turbo. I'm bringing in my FM to our trusted mechanic to replace engine supports. Hopefully sabay ko na rin palinis yung turbo since my unit doesn't have an oil catch can.
August 8th, 2010 12:18 AM #119
PB ang dumi ng loob ng intercooler! Ganyan na rin siguro kadumi yung sa akin.
Tapos na ikalibrate yung sa akin sa Central diesel. Butas yung bulsa pero ok na at one start nalang using yung autostart function ng alarm.
Papano pala icheck yung glow plug? Want to see kung gaano katagal yung sa akin before I replace it again.
August 8th, 2010 12:18 AM #120
As long as it is valid, bring a printed copy. Then, they will ask you to use one of the PCs there...
