Results 6,511 to 6,520 of 6591
- Jul 2007
- 119
June 29th, 2010 01:21 PM #6511share ko lang guys, nagpalit ako ng stabilizer link kanina, 1170 ang isa. ok na ulit, wala na yung annoying sound.
paanong sound ito sir?
June 29th, 2010 06:52 PM #6512
my best investment or PM so far = calibration
good points:
1. nawala (halos) ung alog ng FM pag nag engage/disengage ung aircon (napalitan na supports ko, before calibration maalog pa din)
2. nawala "kablag" sa likod or sa differential pag nagshishift sya
3. smoother engine, parang mas naging pino
4. FC ? di ko pa nasusukat...abangan hehe
June 29th, 2010 10:57 PM #6513
Yung sa akin ang susunod na gastos ay yung calibration ng injection pump. Medyo nag hard starting na sa umaga. Quotation ng Central Diesel at 15 - 18K ang gagastosin.
- Jun 2007
- 81
June 30th, 2010 12:21 AM #6514Hi guys, share ko lang repair work sa fm ko. Dahil sa maraming humps sa subdivision namin, umingay (squek) ang front suspensions. Had my rig greased last week, but lalong lumakas ang ingay. So today, ito yong ginawa ng mechanic: replaced 2 upper (Php 1510 for 2) and 2 lower (Php 2100 for 2) ball joints with 555, plus labor of Php 1,400.00; and align Php 400. To my surpise, lumuwag daw nuts/bolts sa suspension kaya imingay
. Ngayon ok na.
June 30th, 2010 06:31 AM #6515
taz13, nagpalit din ako niyan dati, kahit di pa sira, grabe nga yung price niyang stabi link, ang liit liit tapos ang mahal, napansin mo ba na hindi sila same ng color for left and right, isang silver isang tanso pag 555?
nelany, hard starting, pumapalya then namatay, calibration na nga, if you think na ok pa takbo pag mainit na, ok rin FC mo and walang usok, pwede mo sabihin na wag muna palitan injectors, lalabas yan 10k nalang sa cdc.
larshell, no problemo bro,
June 30th, 2010 06:33 PM #6516
Finally, board is up.
I availed of the full ATF flush (aka Transtech) at Fronte, Banawe. I advise buying ATF somewhere else since they charge 200/liter.
Breakdown:
10 liters Whiz ATF (155/quart at Carline) - 1550
MOC ATF Cleaner + Suplement - 850
Labor - 700 (Discounted care of their 'boss')
June 30th, 2010 11:37 PM #6517
i STRONGLY suggest to have it calibrated na. you won't know WHEN it will DIE on you....
ganyan nangyari sa akin, meron na symptoms (ilang months) pero since umaandar pa, hinayaan ko muna. nag change oil, change GP's pa nga ako, bumyahe pa ako bolinao.
paguwi ko galing bolinao dun namatay, at least sa bahay lang ako and di gamit ni misis. nagpa tow truck tuloy ako papuntang calibration center
actually balak ko na din pa calibrate kasi palyado na. naunahan lang ako ng tirik pero alam mo naman pinoy, minsan dinedelay pa natin
costed me 20k, palit halos lahat. in a way parang holdap, naisip ko "sana dinala ko sa mindanao calibration kasi mura dun" pero naisip ko nlang "sige na", at least isang trabaho nlang
- Jun 2004
- 476
July 1st, 2010 11:22 AM #6518
July 1st, 2010 05:15 PM #6519
July 1st, 2010 05:58 PM #6520
Sir blue_gambit they sucked out most of the old ATF, including those stuck in the torque converter. Whole procedure took about an hour siguro.
I decided to buy ATF somewhere else kasi nga 8 liters of ATF lang yung kasama sa P3200 package nila. So if I availed that, I would have spent around 3600.
How about 97 LXi?
Civic horsepower
