Page 616 of 660 FirstFirst ... 516566606612613614615616617618619620626 ... LastLast
Results 6,151 to 6,160 of 6591
    Mar 2003
    #6151
    colosus, sorry bro taga province kasi ako, cant recommend a mechanic. imho servitek is ok, meron narin sila alignment. para di kana lilipat, pag oil leak alamin mo muna anong oil yan, tatlo lang yan, yellow is gear oil, red is ATF, black is engine oil. usually oil leak galing sa half moons ng valve cover. harap at likod yun.
    Jun 2008
    #6152
    bale pards pb, yung oil is from the rear part of the propeller pala (correction), near sa diff. what do u think of that, oil seal kaya? and magkanu naman ang usual na charge ng servitek sa labor nila sa suspension naten?
    Sir paj4x4: saan po sa banawe ang motorcraft? anu po ang landmark? near them.
    Mar 2003
    #6153
    collosus kulay ng oil?
    #6154
    probably an oil seal on the prop shaft on the diff. unless its gushing down from the tranny.
    I dont know if it will be of use to anyone here, but I tried sa isa kong auto nung mahirap humanap ng oil seal. Is to go to an Oil seal centre, I measured the dimensions of the oil via caliper or bring the sample itself. And the price I paid was significantly cheaper than sa auto supply and it was japan made. They also said in the absence of their stock, they can even fabricate me (minimum of 3 I think) those oil seals I require (industrial grade), though that would be locally. Also they are quite knowledgeable as to the pairing of oils seals, as some oil seals are just dust cover and they have an internal pair, such as those on a power steering box that are sources of oil leaks. FYI lang
    Sep 2009
    #6155
    just had my rig changed oil today, habang naka lift siya ipinatrace ko sa technician kung san galing source ng leak na langis, kasi at first I thought it was from the back half moon, di naman kasi malakas ang leak just a drop or 2 in a week, the technician found the source in the power steering pump areas so I suspect na one of the oil seal or o ring to, kasi parang lagi ngang maitim o basa sa area na yun,...sana nga o ring lang,,
    Aug 2005
    #6156
    bougartt, mas ok siguro pag nag check ka ng pajero, dapat yung malamig na malamig yung makina, yung na overnight na hindi na start, mas ok pa nga kung mas matagal, yung unang start up will tell you alot about your pajero, baka hard starting=(glowplug or battery), baka pag fire up buga ng black smoke, baka mayanig na makina pag start=(engine and AT supports), baka may ibang tunog(fanbelts or bearings), baka pumapalya (injection pump seals), baka yung idle bumababa ng husto(dapat 750 to 800 rpm lang, pag malamig nasa 700 rpm siguro dapat wag mayanig), imho a healthy pajero should start smoothly, susi lang dont step on the pedal. pag uminit na kasi makina natatago mga minor defects niya.
    Promdiboy, thank you so much.
    I started the Pajero and it blew black smoke when I started it. The owner says that its normal for any diesel suv to do such thing. Is that true?
    I also stepped on the accelerator pedal while it was on Park, and it would nudge everytime i'd step on it. The owner said that it was a sign that the turbo was still strong. I'm so not sure about what ever he says. All my cars are gasoline feed (CRV and Jazz) so I'm pretty stupid when it comes to Diesel SUVs..
    Hope you could help me out.. I also noticed that the Pajero sits pretty low.. As if it was lowered..Could the adjustable "Soft" Suspension mode be the reason why it sits low?
    #6157
    Quote Originally Posted by bougartt View Post
    I started the Pajero and it blew black smoke when I started it. The owner says that its normal for any diesel suv to do such thing. Is that true?Mine doesn't, puro carbon deposit siguro exhaust pipe nyo sir.
    I also stepped on the accelerator pedal while it was on Park, and it would nudge everytime i'd step on it. The owner said that it was a sign that the turbo was still strong. I'm so not sure about what ever he says. All my cars are gasoline feed (CRV and Jazz) so I'm pretty stupid when it comes to Diesel SUVs..wala kayang kinalaman turbo dun sir, kaya nga Park para di gumalaw yung car di ba?
    Kung gen 2 & 2.5 yung front height I think is adjustable cause its torsion bar springs, yung rear naman its down to the springs. IMHO
    Mar 2003
    #6158
    pajeri, kakatapos ko lang diyan, dont forget to buy yung o ring in between the PS pump and engine. hiwalay siya sa repair kit ng PS. may pics and info ako a few pages back. pati yung hose kasi pag kinalas hose mag ka crack siya. para di ka balik balik sa bilihan ng parts,
    1 liter pala ang PS fluid na kailangan
    bougart, like what pareng BG said kung 2001 pa yung pajero mo malamang sira na adjustable niyan. silip mo shocks kung oem pa.
    #6159
    mga sir ano maganda gawin sa field master na pumapasok sa loob amoy ng usok ng mga sasakyan sa labas kahit sarado na vent?
    Mar 2003
    #6160
    junkun, check for air leaks muna, spray ka perfume sa loob ng black grill sa baba ng windshield wiper mo sa passenger side. then mag tambay ka sa loob with aircon on. pag naamoy mo sa loob it means yung vents mo hindi na sealed, palit na ng foam.
