Page 613 of 660 FirstFirst ... 513563603609610611612613614615616617623 ... LastLast
Results 6,121 to 6,130 of 6591
    Jun 2004
    #6121
    GAS GAUGE PROBLEM: minsan aangat tapos bababa
    UPDATE: pina check ko grounding, ok naman. nung hinugot ung float valve, ayun may malalim na portion dun sa parang tingga kya siguro pagpatak sa level na un, naglalaro ung gauge ko.
    RESULTS: hininang nung electrician ung malalim na portion, sort of binuild up-an nya ung bunge para pantay sa profile, ayun so far so good! nakatipid ako sa palit float valve hehe
    #6122
    thanks sir dsdelacruz and sir archi:D
    will try removing latch again.. hehe hindi ko matangal nung isang araw eh
    btw our gen2.5 has same problem as yours.. yung gas tank.. pinagawa ng tatay ko nung monday.. nilinis then umok... under observation pa
    Jun 2004
    #6123
    Quote Originally Posted by spec3 View Post
    sir promdiboy - thanks for the reply.
    mga gurus another question, yun bang differential natin eh LSD type (limited slip differential)? '99 m/t 4x4 po specs ng sa akin.
    til now wala pa po ako makitang gear oil na match sa pajero
    thanks in advance
    As far as I know hindi LSD ang diffs ng Gen 2.5. Eto required gear oil specs for the diffs.
    Front Diff
    - GL 5 Hyphoid Gear Oil
    - SAE 80/90
    - 1.2 liters
    Rear Diff
    - SAE 80/90
    - 3.2 liters
    I use Castrol Hypoy C Gear Oil SAE 80w-90 or Mobil 1 Fully Synthetic Gear Oil 75w/90 for the 2.5's diffs.
    Jun 2004
    #6124
    Quote Originally Posted by Aoshi Shinomori View Post
    sirs,
    good pm po! tanong ko lang po kung saan maayos magpa-calibrate ng Gen II sa pasig area? sabi kasi sa casa for calibration na ung pajero namin at medyo may kamahalan sa casa so i'm looking for an alternative kung may-a-advise po kayo. salamat po.
    I suggest you go to Denso in Banawe. Maayos sila don. More expensive than the usual tabi tabi calibration shops but you get a quality job.
    Nov 2007
    #6125
    Quote Originally Posted by dsdelacruz1 View Post
    IN my search for a repair and service manual ng Pajero FM Gen 2.5 I was able to get a copy of the 4m40 engine TD 2.8 SERVICE MANUAL.
    Anyone interest to have a copy just let me know. give me your email and i'll be glad to send you a copy. PDF format and mga 3mb lang. Sa engine lang po ito ha not the entire FM gen 2.5 vehicle
    No success yet in finding a repair manual for the whole vehicle which includes all body parts, electrical system, suspension etc... Nakuha ko Pajero 2001-2002 but it's not the same as the one we have. Meron akong nakita 1991 -1999 pero iba rin parang Gen II
    Sir,
    Pa send po naman at my email address : mqtiglao*gmail.com
    Salamat.
    Nov 2007
    #6126
    Sir,
    Salamat.
    #6127
    sirs,
    sir try ninyo sa zexel east calibration... its located along marcos highway, sa petron gas station mismo located sa may salve regina hospital...
    contact number 6462661
    sila gumagawa ng mga calibration ng union motors
    Oct 2009
    #6128
    salamat po sa copy sir dsdelacruz1
    #6129
    guys ask ko lang po.. bakit sa ibang bansa meron silang nilalagay na copper grease sa pads? dito saatin meron ba?
    #6130
    Hi guys im new here and also new when it comes to cars, especially paj's but I really hope someone can shed some light to my ignorance in these subjects
    I have a very cheap secondhand converted 3 door pajero. My first problem is a clicking sound in the right front wheel when braking, even when braking slightly, sounds like the brake in the right side is delayed hehe then justs clicks in for no reason after a second.
    Second is the sunroof rubber guard on top of the car roof not the rubber guard inside.. it's not a sliding sunroof btw. Can these be replaced? Any idea on the price?
    Third but not the least is the fan. Aircon seems to be running because when i turn the AC switch on i can hear another fan and the whole thing rev up but no air flows through the vents... sana fuse lang hehehe. Sorry for being so noob, I've been driving for 15 years but I dind't really pay attention to these details until recently.
    Thanks in advance
