Results 6,001 to 6,010 of 6591
- Feb 2010
- 336
April 8th, 2010 06:14 PM #6001*sir rts, tarlac based po kami it would be better if we could see the unit kindly PM nyo lang po kami where's the unit located so i can schedule an appointment...we're not in a hurry naman po.
any other referrals or offers is highly appreciated, thanks po sa mga replies
April 8th, 2010 07:13 PM #6002
- Jul 2008
- 114
April 8th, 2010 09:28 PM #6003This forum is really helpful- for the practical tips as well as sa mga contacts from where to get supplies and services.
Share ko lang din for those who will be similarly situated. Last week e bigla na lang umilaw yung A/T, fuel filter and battery indicators. Hindi nawawala pero umaandar pa naman ako. I was told it's definitely "alternator problem."
So dinala ko Pajero sa Rey's Electrical Shop sa Marikina. After the testing, hindi nga daw nagkakarga yung alternator. Sira pala yung diode nya. P3600 din inabot. Ok na rin, at least gumagana na ulit sya. I inquired sa casa, 50k++ pala ang new alternator.
Regards to everyone here.
April 9th, 2010 12:23 PM #6004
good day po mga kapaj tanong ko lang po sana sa mga nakapagpalit na ng water pump sa fm nila kong san po kau nagpagawa na shop at kong magkano po inabot kc nakita ko kaninang umaga sa fm ko parang basa don sa may pump pero pagpinaandar na nawawala po yong basa kailangan na po ba kayang palitan or lilinisan lang po? salamat po
April 11th, 2010 02:13 PM #6005
Hi,
Anybody out there who knew what shop can repair the horn? I need to disconnect the orig horn layout in the wheel cover(4 spoke)naglagay na lang muna ako ng temporary botton sa left side panel(done by autoelect.) I went to mits casa, ang suggestion nila to replace the whole cover including yun air bag, which will cost P40k, sabi ko wala naman problema ang air bag iyun lang horn dahil grounded(continuous blowing). I hope someone out there can refer me sa talagang gumagawa o na nakapagpagawa na.
Thank you-Artee
- Jun 2004
- 476
April 11th, 2010 02:22 PM #6006
- Jun 2004
- 476
April 11th, 2010 02:27 PM #6007Had my rig's ('99 FM Local) water pump replaced in 2008. Got OEM from El Dorado. Sinabay ko na rin pati thermostat para isang gawa na lang. Had it replaced in Motorcraft - where I have all my rigs serviced post casa warranty. Mahal lang pag OEM pero so far no problems. Motorcraft is along Banawe. Maayos don. You just need to be there really early as the lines do get long.
April 11th, 2010 02:36 PM #6008
ako naman had my 95 pajero's water pump replaced nung 2007 naman. bought the original water pump from motorix then had my suking home service mekaniko do the replacement of the water pump as well as the timing belt and seals para isang gawaan nalang....do try to getthe original para sure na tatagal at di ka malugi sa labor.
- Nov 2007
- 54
repair kit lang. car care nut says, for toyotas, he recommends entire assembly replacement for...
rack and pinion repair
