Results 5,981 to 5,990 of 6591
- Jun 2008
- 64
April 4th, 2010 12:03 AM #5981actually sir gambit, hindi ko pa nachcheck ang steering box, and other parts nya, aside wat ive mentioned. saang reputable shop kaya pwedeng ipadiagnose ang auto ko? tnx
April 4th, 2010 12:15 AM #5982
I dont know of any shop, kasi backyard mechanic lang pinag papagawaan ko. You yourself can check the steering box, you can check it via the wheel well at the front driver side. just lift the rubber curtain close to the chassis and you can see it, kung magagalaw at maaalog mo yun, problema nga at kung kulang ng turnilyo. Yung sa steering shaft, sa ilalim ng dashboard firewall doon mo naman makikita running up to your steering wheel, dapat solid din yun. Yun kasi sbi sakin ng kumpare ko na mechanic...
- Sep 2005
- 110
April 5th, 2010 05:43 PM #5983
April 5th, 2010 06:16 PM #5984
April 5th, 2010 06:31 PM #5986
2 problems:
1. pag cold start, dati ok ang menor ngayon parang tren (jug jug jug) na mababa, ayoko bigyan ng gaso kasi alam ko masama sa diesel engine un kya on na lang ako ng aircon. unless apakan ko muna gas pedal before starting. signs na kayo ito ng calibration pagtagal? lagi naman ako naka petron booster kada full tank
2. nagpalit ako t-case support pero medyo may alog pa din pag nag engage ung a/c. engine support kya? ano pa ba ibang supports na pwede palitan?
April 6th, 2010 04:38 AM #5987
archi, 1. my guess is timing chain sound yan kasi wala pang oil pressure. yung tensioner kasi natin oil pressure ang nagpapagana. no oil pressure + no tension + no oil (di pa umakyat sa taas) = loose chain (jug jug jug sound). 2. AT support, mas ok kasi sabay TC and AT support. check mo TC support mo kung naka float pa yung gitna, kung nasa baba na, malamang AT support mo bumaba narin. imho dont change your engine support unless may crack. nagpalit ako niyan at 100k kms, no cracks yet yung luma, halos walang difference sa bago.
April 6th, 2010 10:35 AM #5988
wow daming barya sa ilalim.. im glad you found info useful
hehe
naalala ko tuloy bibili ako fuse... sabi sakin 2pesos... kalog kalog bulsa.. wala barya.. wala din 100... 500 smallest bill.. ayaw ako bentahan fuse na 2pesos.. naalala ko tuloy halungkat ako... sa carpet.. hehe nakakuha ako 4pesos.. 2pcs pa na fuse nabili ko.. hehehe
btw... hehe one more thing about coins sa carpet.. i use to work sa casa.... body repairs... pinagsasabihan namin car washers... bawal kumuha barya na nasa dash... but alam ko kinukuha nila mga barya sa sahig.. tawag nila dun vacumm.. hehe
sir bigbrox..
kaya po lagyan hid fogs natin kahit maliit case.. hindi lang po iclose lid sa likod.. sa tatay ko nilagyan ko nalang ng ductape.. hehe
- Sep 2005
- 110
April 6th, 2010 12:20 PM #5989
question: dangerous ba ang kasong ganito? mines also like this.. pag high speed noticeable sya, pero since puro city driving ako 95% of the time parang tinatamad nako pagawa... wat do u tink mga bossing? i seldom go fast naman, pag nasa c5 lang or slex (c5 to sucat) lang once a month... delikado ba?
- Apr 2010
- 13
April 6th, 2010 05:44 PM #5990sers,
newbie lang po, itanong ko lang po sana kung magkano usually ang range ng mugs ng FM at san makakabili? i-upgrade ko sana mugs nung sa akin kagaya ng sa FM. salamat po.
repair kit lang. car care nut says, for toyotas, he recommends entire assembly replacement for...
rack and pinion repair
