Page 596 of 660 FirstFirst ... 496546586592593594595596597598599600606646 ... LastLast
Results 5,951 to 5,960 of 6591
    Aug 2009
    #5951
    Hello gentlemen,
    I'm posting this in behalf of my cousin's Pajero problem.
    Unit: 1995 2.8L JDM Pajero
    Engine: 4m40, automatic transmission
    Problem: As claimed by my cousin, there is a hissing/vibrating sound on the belt that connects the compressor to the main engine (pero bagong palit yung belt kasi nagpalit na rin ng compressor)
    Initial diagnosis: Replace crankshaft pulley (as claimed by their mechanic)
    Just inquired at Motorix, the part costs PhP 9,000 bnew Mitsubishi, while at Autostar (banawe also) the part costs PhP 4,000 Taiwan replacement.
    Due to budget constraints, is it ok to buy the Taiwan part? Is this normal wear and tear or could it be caused by other factors?
    Your advice will be very much appreciated. Thank you.
    Jan 2010
    #5952
    paj4x4 - totally flush out sya inalis ang pan nya as in tinuyo..low cost fluid lang nilagay ko naka 2days naging ok sya lumilipat ng gear. tpos balik n ulit til 3rd lang follow up question. dapat ba magpalit ako ng fluid ulit o ok na rin yung nilagay ko..? speedometer hindi rin gumagana anu kaya dapat bilhin o palitan? rpm ko gumagana naman. tnx pardz
    garci - wow ganun pala kamahal yung speed sensor..yeah i where baltak's is..tnx broh. buti nalang may mga ganitong forum..my pajero is A/T. 4x4. mukhang pagod na din sya naka 320K n mileage hehehe
    actually madami pa ako mga parts kailangan like ff:
    1. letter "A" ng pajero emblem
    2. shifter bushing
    3. transmission support
    4. shocks sa harap 1pc driver side
    5. speed sensor
    6. papabalot pa ng steering wheel
    ang transmission kaya na galing sa surplus japan matic match o pede ba gamitin?
    tnx God Bless mukhang mag shopping ako sa banawe ah
    Nov 2007
    #5953
    Quote Originally Posted by lucskudkil View Post
    2. shifter bushing
    5. speed sensor
    Hi mga gurus, when do you know its time to replace the shifter bushing ?
    Mar 2003
    #5954
    kcboy, nakakamiss nga talaga, ngayon kolang naintindihan sinabi mo dati.
    lucskudkil, 320kkms, wow!!! naoverhaul na ba? sana maabot ko din ganyang mileage
    pajman, pag maalog na yung gearshift, to the point pag naka idle ka, naririnig mo nagraratle yung gearshift. kailnagan mo pa hawakan yung kambyo para di maingay,
    #5955
    pb,time to replace the shocks (audible na knocking sound), try ko kyb fluid,nagpabili ako sa coltline,try ko kung hindi na aaruy mga balljoint pag nalubak sa harap,tama kaya presyo nito o tama kaya yung shocks na nabili?, kasi 600 pesos lang isa, mahal pa yata shocks ng bisekleta ko dito, hindi kaya after one month magpalit na din ako kaagad?
    Mar 2003
    #5956
    pr462, mga 800 lang din yata kuha ko dati. Kyb fluid.
    #5957
    Mura pla kapag fluid type shox, parang pang AUV din ang price...
    pb kamusta naman ride nung fluid ginamit mo? parang soft setting ba or softer?
    Jun 2008
    #5958
    Hello, sino na po dito nareplace na yung piston rings nila ng 4m40 engine. Recommendable ba yung NPR na piston rings and how much po ba ito?
    #5959
    Pb ask ko lang, me tune-up ba na ginagawa para sa 4m40, like adjust tappet valve clearance? or just change oils, and filters lang? thnaks
    Nov 2007
    #5960
    Hi PB, I think i need to replace my shifter bushing.... malapit na... how easy is it to replace? madali lng ba? how much kaya damage? salamat .
