Page 585 of 660 FirstFirst ... 485535575581582583584585586587588589595635 ... LastLast
Results 5,841 to 5,850 of 6591
    Jun 2009
    #5841
    Quote Originally Posted by TAZ13 View Post
    RTS magkano total damage mo nung pag bypass? may switch ka na ba sa loob pinipindot for that?
    *TAZ13
    Hi, the by pass no other switch was installed, still the same layout, mayroon lang inilagay parang timer. Material cost P1300 including new set of glow plugs & heat senso ,plus labor P900
    RTS
    Jun 2004
    #5842
    Quote Originally Posted by stadaenko View Post
    if i remember correctly, mga 14K sya at that time. i didn't ask wether the seats had oem frames or not.
    Thanks. I'll check with Seatmate this weekend. Check ko na rin sa old reliable suki ko na si Boy Chincuanco baka meron din siya.
    #5843
    nelany, grabeng mura nga ng tires mo, did you check the production date? just to be safe
    PB, yup meron pang 4 years tire life siya. Nasa gray market siya kasi.
    #5844
    [quote=blue_gambit;1425376]sir san mo na kuha yan, ang mura naman? pm mo naman ako where? thanks. pag 10K lahat, pati spare ko papalitan ko na rin
    Blue gambit, PM sent.
    #5845
    Quote Originally Posted by azzkkr2600 View Post
    sir, kindly PM me where i can get cheap general grabber tires. i just need one though for my spare.
    Bro, PM sent.
    #5846
    Thanks sir nelany
    [quote=nelany;1425955]
    Jun 2004
    #5847
    Hi Nelany. Galing nyan. Interested din ako to get a set at that price. Appreciate if you can PM the details. Thanks.
    Dec 2009
    #5848
    Quote Originally Posted by janrye26 View Post
    follow up ko lang po
    janrye26 hope this helps:
    Pajero 4WD Flashing Light Fix and Troubleshooting
    Good luck!
    Aug 2007
    #5849
    Quote Originally Posted by patricksxy View Post
    Good luck!
    thanks po sir patrick
    Jun 2009
    #5850
    Mga Sirs:
    about my problem of continuous blowing horn,my wife brought the pajero to our suking shop, the electrician was able to remove the steering wheel but the horn cover was intact & unable to go deeper sa horn activation portion, the elect. suggestion is to cut the soft plastic cover so he can have access to the mechanism in which i said NO, anyone who can recommend shop that is well verse in this kind of job without disturbing the air bag set up, pls.feed me up, Im living between caloocan & quezon city boundery.
    Thank you for any help-
    RTS
