Page 579 of 660 FirstFirst ... 479529569575576577578579580581582583589629 ... LastLast
Results 5,781 to 5,790 of 6591
    Oct 2009
    #5781
    mga sirs gandang umaga newbie lang ako dito hingi lang ng tulong :D
    naka fieldmaster din po ako local nagkakaproblema kasi sa umaga ang tagal uminit ng makina ng pajero ko hindi mo pwdeng patakbuhin agad pumupugak-pugak yung makina pag minadali pero sa mga kapitbahay ko naman kahit luma na tsikot nila kahit kaka start lang pwede na agad nilang mapaandar. bkt po kaya ganun yung akin?
    #5782
    dlxrevo, tama yung comment ni rts pwedeng hose lang, kung gusto mo check yung sinabi ni rts, silipin mo sa engine bay, sa taas mismo ng wheel well ng passenger side. may magkatabing dalawang solenoid dun, marked by yellow and blue dot na sticker kung tama alala ko. sundan mo lang yung mga vacume hose na yun kung may cracks or butas, dapat air tight yan.
    pag walang cracks mukhang casa kana siguro.
    *promdiboy:
    thanks pb.
    #5783
    Quote Originally Posted by RTS View Post
    I had the same problem before 4WD blinking, so I brought it to the casa, they found out that the little like hydraulic hose ay meron small crack sa dulo ng connection, they just re-cut the end & balik ulu, no charge that simple, I hope ganoon din ang problema mo.
    RTS
    *RTS:
    salamat po
    Jun 2009
    #5784
    Quote Originally Posted by gioravelo15 View Post
    Let me guess, could it be your glow plugs not burning properly if not totally "kaput". the pupugak pugak behavior is due to your diesel fuel not yet heated or your fuel system was drained overnite. Your kapitbahay cars are run by petrol & not diesel which is completely different to each other.
    RTS
    #5785
    thanks sir pb, tama ka nga. ma trabaho nga lang. at least nawala yung kalampag. yung sidings pala culprit sa naririnig ko, kasya pla 6x9 dun sa likod. I wonder how much it would cost? 6'' na full range lang pala naka kabit doon sa likod, kaya pala bitin. hehehe
    bg, kailangan mo kalasin yung 3rd row seats. Then yung sidings naka screw sa floor.
    Oct 2009
    #5786
    RTS
    sir RTS salamat sa reply iniisip ko nga din baka sa glow plugs Chipipay lang kasi pinalit namin. Delikado ba pagka na drained yong fuel system? ano pwde ko gawin para ma slove to? salamats!
    nga pla mga sirs ang bilis din mamatay ng heater light ko sa dashboard mga 4 seconds or 6 mawawala na nag gi-green light pa po ba un na sign na ok na? or orange tpos mawawala na?
    thanks!
    #5787
    sir gioravelo.. pag replacement po.. use hkt or jkt po... sakin tumagal ng 1 year din... bumili ako ngayon orig pero... nilagyan ko na ng switch para pag start nalang glowplugs ko.. hindi na siya gagana para magpainit ng makina.. hehe
    btw gen2 lang po akin:D
    May 2008
    #5788
    Packed day again tomorrow. Will be replacing (1) front shocks, (2) Power steering return hose, (3) right pitman arm. Grasa na naman
    #5789
    guys.. senxa na if OT to, just want to asked how much is the rear aluminum step board of pajeros? and where can i buy a surplus stepboard thats still in good condition. thank you guys..
    #5790
    I have an 03 Pajero FM, local... pag umabot ang rpm sa 20000,whether standby oor running, there will be a loud sound coming from the intercooler, parang "wwwwiiiiinnnningggg...."...
    I tried doing a some testing.. When I disconnected the suctioned (upper) hose of the intercooler, wala ang sound upon rev... Pag yun sa hose(lower) tinanggal then connected upper hose, may ingay pa rin.
    Can anyone help? thanks
