Results 5,771 to 5,780 of 6591
February 17th, 2010 11:53 PM #5771
dlx, based sa mga namention mong symptoms, mukhang naka 4H ka, baka ayaw bumalik ng 2wd kaya ganyan.
- Jun 2008
- 41
February 18th, 2010 12:12 AM #5772Sir promdiboy,
Sorry now lang me nakareply, nagtotopak minsan ang forums eh. Uhm, naidentify ko na yung problem ng FM ko. Yung main problem pala with my FM is ung Injection Pump! yung naka kabit na injection pump is yung pang 4d56 or ung Gen2 na pajero. Kaya maingay sha and walang hatak. Pero now pinalitan na. But I have still minimal
problems of it.
You have an idea on the injection pump gear? Yung "T" and "N" na symbol? Saan po ba dapat naka align yung gear?
And about ung sa ignition lights ng engine natin sa dashboard. Nung pinarepair ko kc, after nawawala na ung ignition lights sa dashboard. Yung engine na kulay red ung symbol and ung kulay yellow na spring. You have an idea kung saan located ang mga wires nila sa engine bay?
Paano pala linisin mga mufflers natin? diba dalawa daw yun?
Thanks =)
February 18th, 2010 12:34 PM #5773
chilledo2, hindi ko kabisado internals ng IP. paano nangyari mapalitan injection pump mo na pang gen 2? mukhang niloloko kana nung calibration shop. suggest ko dalhin mo na yan sa CDC.
- Jan 2006
- 15
February 18th, 2010 01:11 PM #5774* badongski
I meant yun 4WD indicator lights ... blinking kasi sya at I'am not sure kung saan sya na stuck kung sa 4H or 2H or worst baka hindi fully engaged ang anumang gear ... hehehe
Hindi naman mausok kaya lang medyo makupad sa arangkada, malakas sa krudo, hirap sa paakyat at medyo maugong ang makina.
Do you know anyone who can fix the 4WD indicator lights problem. I already followed yung guide to fix the blinking lights but ... ala nangyari
- Jan 2006
- 15
February 18th, 2010 01:14 PM #5775
February 18th, 2010 01:58 PM #5776
February 18th, 2010 02:03 PM #5777
mga peeps pakisuyo lang po for i know dito lahat dumadaan pajero enthusiasts..
im selling my 1997 2.5TDIC (4D56 engine) 4x4MT local release pajero
moving back to Alaska po with the whole family and would need to let go of my cars here in manila ...
PM nlng po for complete details sa interested ..
NOTE: NOT flood damaged 100%
thanks for your time
February 18th, 2010 02:32 PM #5778
I had that problem of blinking 4WD indicator before, so nung dinala ko sa casa, they check under, they found out that the end of the hose has a minor crack on the end connection, they just re-cut the end & put back, presto nawala na iyung blinking, I hope ganoon din ang problema ng sa iyo.
RTS
February 18th, 2010 02:43 PM #5779
February 18th, 2010 11:30 PM #5780
dlxrevo, tama yung comment ni rts pwedeng hose lang, kung gusto mo check yung sinabi ni rts, silipin mo sa engine bay, sa taas mismo ng wheel well ng passenger side. may magkatabing dalawang solenoid dun, marked by yellow and blue dot na sticker kung tama alala ko. sundan mo lang yung mga vacume hose na yun kung may cracks or butas, dapat air tight yan.
pag walang cracks mukhang casa kana siguro.Last edited by promdiboy; February 18th, 2010 at 11:33 PM.
repair kit lang. car care nut says, for toyotas, he recommends entire assembly replacement for...
rack and pinion repair
