Page 577 of 660 FirstFirst ... 477527567573574575576577578579580581587627 ... LastLast
Results 5,761 to 5,770 of 6591
    Jun 2009
    #5761
    Quote Originally Posted by pr462 View Post
    RTS, i spent more or less the same amount nung napalitan mga o rings and seals on the steering box, ang daming goma niyan,pag natapos ay puede ka makipaglaro sa mga bata ng tantsing ng mga goma,pa check mo din mga steering hoses mo, sa akin dun nagstart, sa hose nag leak, nung naayos yung hose, nagkaroon naman ng leak sa may power steering assembly...nagsabay sabay na...pero as of now malinis na makina, wala ng tumutulo maski ano....umiilaw na lang nga paminsan minsan a/t light sa dash...
    patricksxy, ako 30 all around tumipid sa diesel, maganda ride ng 26 in front pero parang mukhang malambot....
    *pr462
    Thanks for the input, at least I have the charted water.
    Rgds.,
    RTS
    Mar 2003
    #5762
    rts, post kayo pics kung gaano karaming kakalasin sa gearbox ng FM, so far wala pa akong leaks diyan, may nag adjust ba ng gearbox mo prior siya nag leak?
    patricksxy, front ko 36 the rear ko 40 psi. tapos naka soft lang parati suspension setting.
    #5763
    sir pb ecu pla ng 4wd gearbox yung nakita ko sa likod ng head unit. I stumbled upon a thread in australia regarding it. Its on the link below
    http://www2.pajeroclub.com.au/forum/...ead.php?t=9242
    Dec 2009
    #5764
    pr462, promdiboy: recently tried the 26/29, for me *parang* masmataas consumption ng diesel. try ko both your suggestions thanks!
    Jun 2009
    #5765
    So far first time since from casa (2000)4 pcs upper bushing this will be the 2nd time, though the leak is not causing immediate problem except the untidy sight of oil streak, sabi nun mekaniko just always have a check of the level of steering fluid(ATF) kung hindi pa ako ready sa job order.
    RTS
    Mar 2003
    #5766
    bg, sa local FM kulay blue yung ecu ng super select.
    #5767
    Sir pb, mukhang mahilig ka sa sounds. I saw your car domain profile, very nice ride and sound set-up. Would you by chance know how remove the rear speakers? yung nasa third row? yung grill ba ng speaker detachable ba? or kelangan ko pang kalasin yung buong plastic moulding?
    #5768
    Hello Gurus - Yung blinking lights problem po ba ng 4WD eh nakaka apekto sa performance ng Paj natin?
    Ex: Lost of power, mahina sa arangkada, walang overtake power, hirap sa paakyat.
    I was thinking kase to have it fixed muna before I go to central diesel to have my unit diagnosed.
    Ano po sa palagay nyo?
    Salamat po.
    Mar 2003
    #5769
    bg, kailangan mo kalasin yung 3rd row seats. Then yung sidings naka screw sa floor.
    Dec 2008
    #5770
    dlx revo sa pakakaalam ko walang kinalaman yun blinking sa 4wd
    bat mo dadalhin kay central diesel, mausok na ba yun paj. mo?
