Page 576 of 660 FirstFirst ... 476526566572573574575576577578579580586626 ... LastLast
Results 5,751 to 5,760 of 6591
    Jun 2008
    #5751
    Sir blue_gamit,
    Yung ingay is I think nasa engine. Pero im not sure kasi ung ingay is located sa baba ng engine eh dun din located yung transmission diba? And di pa namin napa compression test, sinabi lang ng mechanic na piston na because lahat na major parts napaayos and nareplace na namin. Calibrated na din yung injection pump. I need your help and advice sir. Thank you for reading.
    Mar 2003
    #5752
    dcarin, may nakita akong old pic ko, naka bilog ng dilaw. get oem kasi yung replacement nakagamit ako dati nung walang mabili dito, nagloloko hindi parati umiilaw. 150 lang yung replacement 500 yung oem casa price.
    andrewbugs, yes normal yan, magiging live siya 5 secs pag ON position, then pag start live uli hanggang uminit makina. but pag mainit na kahit on off mo makina di na gagana glowplugs
    reep, hindi wheel balance, wheel alignment need mo. pwede rin under inflated
    chilledo2, sorry bro hindi ko pa nasubukan yung ganyang problem, kamusta shifting ng AT mo?
    #5753
    Mga Bros,
    Wala bang problem if I used a tire with the size io 255 70R16 instead yung standard tire natin na 265 70R16? Mas makitd lang ito. Meron kasing murang GRABER GENERAL TIRE.
    TY,
    Mar 2003
    #5754
    nelany, pwedeng pwede naman, minimal lang difference niyan sa stock namely mas makitid ng 10mm ang lapad, 1/2 inch mas maliit yung overall diameter, kaya yung speedo mo will be 1.8% slower. lets say speedometer is at at 100kph, in reality nasa 98.2 ang actual speed mo.
    try to check here. http://www.1010tires.com/TireSizeCal...?action=submit
    chilled02, additional question kumakain ba ng langis pajero mo?
    dcarin, eto pa pala pics ng oem sending unit and part no.
    #5755
    TY PB. Check ko kung ok yung tires.
    Jun 2007
    #5756
    thanks PB for the reply. i hope, this time my glow plugs will last longer. ang linis naman ang engine mo
    Aug 2005
    #5757
    Sir PB,
    Maraming salamat.
    Malinaw ang mga pictures and thanks sa suggestion. Practice ko rin basta sa makina, electrical and sensors dapat OEM. Yung specs at tolerances kasi dapat mag match sa pagka design ng makina.
    Dec 2009
    #5758
    Mga Bros,
    TY,
    guys pasingit din, sinusundan nyo yung sticker sa door regarding tire pressure? 26 Fr 29 Rr?
    Jun 2009
    #5759
    Hi,
    Last sat. nagpa check ako ng brake sa forward due paminsan minsan ingay, it turned out okey pa ang mga brake pads, but what they noticed in the steering box are traces of oil leaks, suggestion by the tech. is to dismantle the steering box & replace whatever O ring , bushing etc. are needed. estimated cost is P 9plus K that includes wheel alingment. Do you think & agree that the price quotation is reasonable?
    Your feed back is sought, thanks.
    Rgds.,
    RTS
    #5760
    RTS, i spent more or less the same amount nung napalitan mga o rings and seals on the steering box, ang daming goma niyan,pag natapos ay puede ka makipaglaro sa mga bata ng tantsing ng mga goma,pa check mo din mga steering hoses mo, sa akin dun nagstart, sa hose nag leak, nung naayos yung hose, nagkaroon naman ng leak sa may power steering assembly...nagsabay sabay na...pero as of now malinis na makina, wala ng tumutulo maski ano....umiilaw na lang nga paminsan minsan a/t light sa dash...
    patricksxy, ako 30 all around tumipid sa diesel, maganda ride ng 26 in front pero parang mukhang malambot....
