Page 572 of 660 FirstFirst ... 472522562568569570571572573574575576582622 ... LastLast
Results 5,711 to 5,720 of 6591
    Jan 2010
    #5711
    Question lang po regarding sa fuel consumption ng fieldmaster ko 2003, city driving is 8km per liter, pero pag nasa sctex or nlex even at 100km/hr speed I only make less than 8km/L. if i go even faster it makes worst, mas malakas sa crudo.
    what I should do? calibration na ba?
    ok naman ang hatak at condition ng makina.
    Thanks in advcance
    Jan 2010
    #5712
    sir, tanong lang po, tuwing kelan ba nagpapalit ng ATF fluid? nasa 77k na kasi sakin.
    Thanks
    Mar 2003
    #5713
    bulmaster, mukhang ok naman FC mo. ganyan din akin, but yung atf mo long overdue na kung di pa yan nagagalaw since new. dapat every 20k kms pag drain refill. pag transtech pwede hanggang 40k kms sabay na atf filter.
    nagputik na yung transmission sump ko at nearly 80k kms ko bago pinalitan atf filter. sa lagay na yan i drain and refill every 20k kms.
    Feb 2009
    #5714
    Quote Originally Posted by bigbrocx View Post
    sir if batangas kayo try nyo mag inquire sa amcar calamba, El Dorado or sa Atco pasay. mas mura mura siguro.. mahal tlaga sa casa..
    salamat sa tulong nyo mga tol. sa march bakasyong ako tingnan ko kung anong maganda sa radiator. salamat uli ha
    #5715
    Guys. na observe ko lang sa pajero ko, kung mag press ako ng breaks softly, parang nag-si-swing ang buong pajero ko... has anybody felt this?
    Mahina kasi ako magdrive, max is 50kph lang, and I don't press breaks quickly or hard... kaya na fi-feel ko ang yugyuog every time I press the breaks.
    Apr 2008
    #5716
    mga sir, question lng po. naputol ung tornilyo ng gulong ko sa likod. ano po ba ginagawa dito? thanks
    Jun 2004
    #5717
    Quote Originally Posted by Dudee View Post
    try to reface and change to new pads
    Jan 2010
    #5718
    sir help again pls.. gusto ko pong malamn kung nakaandar mga pajero niyo at pag mainit na tapos binuksan niu ung oil cap or dipstick niyo then may usok na lumalabas sa dipstick, tapos sa oil cap naman po malakas medyo ung usok at talsik ng oil.. anu po ibig sabihin nun po? Pls help naman po.. sino po pwedeng mag expain dito pag ang 4m40 ay blow by na or i mean may sinasabi na ung makina po.. anu mga signs and symptoms po.. pls help po mga sir..
    Mar 2003
    #5719
    dahc, bili lang ng bagong studbolt, mura lang yun. 100 to 150 lang isa.
    #5720
    I was checking out the head unit plug of my radio in the dash board when I saw a yellow box the looked like a battery pack placed on top of the carpet of the transmission tunnel, me nakakaalam po ba sa inyo kung anu yun? parang computer box yata, although I dont know which it does control or if it is an ecu? I need to know baka kasi kelangan kong bunutin, mag dadag dag kc ako ng heat insulation sa flooring sa harap under the carpet.
    Thanks
