Page 559 of 660 FirstFirst ... 459509549555556557558559560561562563569609659 ... LastLast
Results 5,581 to 5,590 of 6591
    #5581
    *jhoma28
    Try mo check yung GLOW PLUGS Fuse, baka kasi putok na. Ganyan nangyari sa amin. Pinalitan yun, saka nagpalit ng GlowPlugs na tig 260 ang isa. Ngayon okay na pastartin sa umaga.
    Things to check regarding glow plugs.
    1. Glow Plugs Fuse
    2. Glow Plugs Relay
    3. Glow Plugs Heater Rail
    4. Wiring.
    #5582
    Just a curiosity, a few weeks back I remember checking out a mitsu strada 4x4 A/T at one of the malls. I also remember asking one of the tsikoteers why is the strada's shifter indicator on the passenger side(wrongside)? Later today I realized that my jdm pajero has the same layout, also the jdm pajero 4wd selector and the strada's selector is on the same (passenger) side. is it possible that the current strada uses the same tranny as the jdm (with different gearing of course) pajero?
    #5583
    Mar 2003
    #5584
    mapl, 4d56 pala engine mo, di ko gaano kabisado. but at 1k mataas na masyado yan at idle, dapat smooth na yan. meron isang belt na maliit sa baba ng timing belt, para sa balance shafts, pag naputol yun magiging mayanig yung engine.
    nelany, ma check ko nga yung akin.
    local gen 2 and gen 2.5 peeps, meron ako balikbayan box na darating from US. Pwede ako magpauwi ng KNN filter for our pajero. baka merong interested? 5,800 each lalabas.
    #5585
    naku pb, bibili ako sa sabado ng k&n filter sa banawe. yun nga lang, hindi cylindrical type ang sa akin, oval type ako eh. 5.5k ang tanong ko dati, ewan ko lang ngayon..
    Mar 2003
    #5586
    testy, e-2871 dati bumili ako niyan, nagakamali lang, binenta ko ng palugi at 2,5k. If your willing to wait I can get you one 4k. pang jdm 4m40.
    #5587
    tempting! hmmmmm... tanong tanong muna ako sa banawe sa sabado. then pag namahalan ako sa offer nila, i'll consider your offer
    #5588
    *promdiboy
    Pacheck ko tom. Thanks
    #5589
    O mga peeps pabili na kayo. This will greatly improve yung performance ng engine. I'm using one already and I would say hindi bitin yung air sa engine. Only need to clean every 20K or more often if you like. Ipasama na yung recharging kit!
    Nov 2006
    #5590
    *PB / *Testament,
    I confirmed the size of the KYB rear shocks's bolt....mas maliit talaga pag replacement...yung OEM kasi yung with sensor, size 17 yung nut ng bolt....pero yung replacement, size 14. I called Bestcolt, Motorix, MIT-PARTS to confirm this...sabe nila, may difference daw talaga. mas maliit daw talaga pg not OEM. in short, maluwag yung bolt compared sa hole ng mounting plate sa body.
    Is that advisable? although pwede masikipan through the washers,bushings and nut...pero looking at the technical side, parang may kalog depende sa direction of force applied to the shocks e....
    any comments po.....
