Results 5,541 to 5,550 of 6591
- Aug 2009
- 5
January 8th, 2010 01:03 PM #5541
January 8th, 2010 02:22 PM #5542
testy, mas maganda siempre may egr, aside from lowering nox it also lowers egt. kung kaya marepair ang egr mas maganda kasi prone ito mapuno ng carbon. kaya nag stuck up ito usually. cleaning with kerosene usually solves the problem. pero pag sira na at ayaw mo na pagawa pwede siya iblock. based sa mga nabasa ko rin dati ang 4m40 ay may lightweight aluminum heads, magaan siya but mas madali mag crack pag nainitan. dito rin daw beneficial ang egr dahil it lower egt (exhaust gas temp).
going green may konting compromise siempre, gaya din ng cat converter at dpf (diesel particulate filter). ito na yung hihina ang arangkada mo dahil sa egr. kaya yung iba para bumilis and less maintenance binoblock na agad. kanya kanya lang naman yan, choice nalang ng owner. either way merong advantage and disadvantage,Last edited by promdiboy; January 8th, 2010 at 02:27 PM.
- Nov 2008
- 81
January 8th, 2010 05:33 PM #5543pb, thanks for sharing, okay din naman gas lalo na pag sa expressway at maganda ang daan matatag siya pero iba pa din oem na naka medium, eh yung kyb gas adjust,maganda ba? and anong setting dapat,puede ba ikabit yung selctor natin or has to be done manually? tks again
January 8th, 2010 11:07 PM #5544
pr462, yeah I agree with you na pag expressway ok yung excel G. ayos ang handling, pag sa uneven roads or potholes ako natitigasan.
hindi adjustable ang kyb gas ajust, IMHO, mas malambot siya sa excel g. but pag nalulubak ako sa front nandun parin yung kablag!!!!. sabi ng mga balljoints ARUUY!!!sa rears ok na yung gas ajust saakin medyo naglalaro na yung likod, sa bigat ng body.
- Nov 2008
- 81
January 9th, 2010 09:29 AM #5545pb, hahaha, tama ka umaaruy nga balljoint pag lubak, pati nga ako napapakagat minsan at baka mabasag ipin ko pag kumakablag yung harap,subok ko magfluid sa harap baka mag improve, tummagal naman kaya considering na mabigat makina natin?
- Aug 2009
- 5
January 9th, 2010 11:53 AM #5546Good day mga bro, I find this forum quite interesting at marami akong natutunan sa inyo.
. Taga Bacoor lng ako at 4 years i drive the pajs nabili kong second hand and no regrets i owned a pajero. Puede bang sumali sa grupo nyo?
- Apr 2006
- 288
- Nov 2006
- 338
January 10th, 2010 01:51 PM #5548
paps,
i bought excel G just a while ago...napansin ko, mas maliit yung shaft nya compared sa original. ganon ba talaga yung replacement na KYB? size 17 ang nut nung original eh. sobrang liit nung sa excel G...ganito ba talaga at remedyo na lang? or mali yung nabili ko? sabe ng auto supply ganon daw talaga pg replacement...kaya binalik ko muna..kasi kakalog kalog yun kahet pa higpitan sa nut since not of the same size sa plate.
comments pls....
thanks
- Nov 2006
- 338
January 10th, 2010 06:13 PM #5550
How about 97 LXi?
Civic horsepower
