Page 554 of 660 FirstFirst ... 454504544550551552553554555556557558564604654 ... LastLast
Results 5,531 to 5,540 of 6591
    #5531
    pb, thanks a lot for the tip .gawin ko over the weekend.btw, kita ko comments mo regarding kyb fluid shocks,nagpalit kasi na ko shocks,ginamit ko kyb sa harap at likod,gas shocks,iba pa din oem,matigas siya pero eventually masasanay ka din pero mayayanig ka pag nalubak ka nga matindi.ang tanon ko ay may improvement ba nung kinabit mo yung fluid sa harap...para din ba nung oem pag naka medium?mukhang may alog na kasi yung isa sa harap ko at tingin ko malapit na ulit palitan. salamat
    #5532
    Tulong naman. Glow Plugs problem, Pajero 97 (LOCAL).
    Hard Starting siya sa umaga. Si pinacheck sa electrician. Busted ang GLOW PLUGS FUSE, pinalitan na ito pati glow plugs mismo. After 1 day putok ulit fuse, then pati glow plugs nasira na din. Ngayon nagpalit na ng glow plugs. After a day nasira naman glow plugs. Ano kaya sira nito. Salamat.
    May 2008
    #5533
    Some alto bumped into my rear bumper this morning. Scratches tuloy Lubog yung hood and basag grille niya though.
    #5534
    Quote Originally Posted by DLX_Revo View Post
    Mga Sir,
    I will have my ATF changed. I want to ask the part number of the ATF filter and how many liters of ATF fluid is needed. Thanks in advance.
    Model: Pajero A/T (japan/subic)
    Engine: 4D56
    Year: 1998
    Mga Sir - baka may nakaka alam ng part number ng ATF filter ng Pajero (japan) with 4d56 engine. Thanks po.
    Mar 2003
    #5535
    pr462, uber soft ang kyb fluid, mas soft pa siya sa oem na soft setting. compromised ang handling but pag panay city driving kalang pag nalulubak ka mas hindi kablag.
    #5536
    Quote Originally Posted by iennod View Post
    yung egr ko rin nagloloko na po. pag sinara ko na po ng tuluyan yung egr may chance po ba na umayos yun?
    may nakalagay kasing pako dun sa vacuum hose ng egr,pang bara. gusto ko ng isara ng tuluyan baka kasi yun yung dahilan.
    parang may nabasa ako dito na as much as possible, wag gagalawin ang egr. may sinabi si pb about dito. as for me, wag talaga. kaya tayo may egr kasi may purpose yan. pag kasi inalis yan, baka maging smoke belcher ang sasakyan. pb, paki-correct nalang kung tama sinabi ko, salamat
    Jun 2009
    #5537
    Glow Plugs Headache....
    I have changed my glo plugs many times(about 4times) from unexpensive to expensive brand for a short span period, finally the electrician Im waiting for showed up & sinunod ko na lang ang advise nya, to by pass the relay of ECU, but I have to buy again the 4 sets of glow plugs, nah I just bought the non- expensive one, plus the temp sensor & some alteration done by the elect. Currently my PJRO (FM 2.8L/MT) under observation, will keep you posted kung okey iyung ginawa
    RTS
    #5538
    landlord... mitsuboshi po:D oem ng mitsubishi and denso...
    Aug 2009
    #5539
    not necessary mag oem ka sa atf filter mo may replacement yan tell them anim ang butas ng atf filter. one set na yan kasama na yung gasket about 800-900 petot ang isang set. katapos lng sa akin, ok naman.
    Aug 2009
    #5540
    Quote Originally Posted by landlord View Post
    I will be replacing my alternator belts. What brand would be a good replacement. Yung reasonable price or so called value for money. Thanks again in advance.
    ano engine ng ride mo bro, if 4d56 ok na yung bando parehas lng sa L300.
