Page 520 of 660 FirstFirst ... 420470510516517518519520521522523524530570620 ... LastLast
Results 5,191 to 5,200 of 6591
    Aug 2005
    #5191
    mtvacs and testament, Mapwa din ako, ECE Batch 86
    Hirap talaga, sorry kung may ma-offend, pero motorcycle talaga mas kalaban sa road now - Overtake and cut from kanan, tight na pag singit, racing with kapwa motor, counterflow etc..
    Suggest ko na lang na we really have to stay focused sa road and be alert.
    #5192
    pag nag eb pala tayo parang engineering eb din?
    Jun 2004
    #5193
    dami gin-gineer! ako alak-kitek ust 95. anyway sige bali balita na lang sa eb.
    so far kakapalit ko pa lang alarm, sub zero, 3k. ok din parang ung features ng cobra old school ko. sabay sa preno ung lock and mag lock uli pag meron ka binaba and nakalimutan ko mag lock. pahinga na orig code alarm.
    changed my horns na din. 2 sets bosch/hella snails. normally 3 sets snails ako hehe.
    then kanina gumagana pala headlight washer ko, akala ko umuusok kasi umuulan un pala nagrereflect ung tubig pag naka washer.
    ang hassle lang sira intermittent ko, always on ang wiper. papa tsek ko pa, hay. sana hindi module/relay or something.
    Jan 2009
    #5194
    *Archijardy - tnx for the prompt reply and advice. I followed it. Had the oil pan and filter cleaned. D naman sobra dumi. And then filled with new oil. But it did not fix it. An electrician replaced the pulse generator and fixed the problem. In just 20 minutes! Didn't realize that it was that easy. Thanks again.
    Jun 2004
    #5195
    Quote Originally Posted by egsunio View Post
    congrats
    magkano inabot?
    Sep 2009
    #5196
    pb, ok na rear disc pad ko had it replaced yesterday, ipina overhaul ko na din caliper tahimik na sa ngayon wala squeel sound di ko lang alam for how long siya tahimik, pwede mo na ibigay ung extra sa iba just in case...napansin ko medyo hard starting na naman ride ko parang glow plug na naman mukang nadale na naman ako ng fake na pyesa...kulang siguro sa init kc pag start kelangan pa salubungin sa accelerator na ayoko sana kasi nga dry start di maganda sa engine...kaya pag start mausok na puti ang lumalabas hilaw ang pag burn ng diesel...di pa kaya ng budget bumili ng oem na glow plug 2500 kasi pinakamurang canvass ko wheww thats 10k just for set of glow plug....
    Jun 2009
    #5197
    Hello mga sirs;
    Glow plugs- persistent problem
    I have change my glow plugs 4 times in a row already, & kung ang problema lang ay I shud go to more expensive lang if that is the cure I will not hesitate to do so, kaya lang baka it will not solve the problem sayang lang. As of now nagtitiis na lang ako ng hard starting, I know it is giving strain to my starter. Ang ginagawa ko na lang I leave the ignition on for quite some time (about 5 min) then start, medyo okey. Ipapa direk ko na lang sana ang heater but my suking electrician is out in the country side. Anybody has done this alteration & gone back to old classical way, independent heater switch.?
    Thanks- RTS
    Sep 2009
    #5198
    same here rts... sana nga kung sure lang na tapos ang problema sa hard starting pwede ng brasuhin ang 10k para sa oem na glow plug if not sayang...pag napadirect mo na heater mo at ok naman post mo lang at ganun na lang din gawin ko....
    Jun 2009
    #5199
    Quote Originally Posted by pajeri20 View Post
    Sure Buddy ,will keep you posted, kaya lang hindi ko alam kung kailan ang balik nun electrician na nag promise kasi ginawa na niya iyun sa mazda pick up ko, he told me before it is more logical than to buy the electronic card of the PJRO.
    Rgds.,
    RTS
    Sep 2005
    #5200
    Quote Originally Posted by archijardy View Post
    WHEW! just finished reading 338 pages for two weeks ata!
    nag-take down ka ba ng notes? baka naman pwede kopyahin ko nalang for persons / repair centers to contact pag nagkasira fm natin? parang ang hirap basahin the whole thread eh...
