Page 512 of 660 FirstFirst ... 412462502508509510511512513514515516522562612 ... LastLast
Results 5,111 to 5,120 of 6591
    May 2009
    #5111
    hello guys, any of you know where i can get this, asked sa banawe pero wala, haven't tried asking sa casa, cause we all know how prices get jacked up pag dun ka nakabile
    if the link won't load look here
    http://www.flickr.com/photos/awpkazuya/4097440484/
    thanks
    May 2009
    #5112
    bat ganon, ayaw mag load
    Jun 2004
    #5113
    Quote Originally Posted by zosotskot View Post
    thanks
    i guess you should visit banawe or evangelista. nagtanong ka lang ba or pumunta ka? pag tanong or tawag kasi, medyo tamad din mga shops dun, dapat bisita talaga. dami surplus, that will do. kanina galing ako evang, dami front cut, accessories, etc.
    pasyalan mo lang sila and i'm sure you'll find one
    May 2009
    #5114
    *archijardy - yep pinuntahan ko sa banawe talaga sir , will try evangelista siguro next time , thanks
    Aug 2007
    #5115
    techconnect, pag glowplugs hardstarting sa umaga, redondo lang ng redondo but matagal bago tumuloy, pero pag mainit na 1 click nalang, pag battery sira mahina mga ilaw pati ilaw sa dash at busina, pag start mo click lang.
    ikawngaba and archi, Pm sent,
    sir PB, maraming salamat
    Jun 2004
    #5116
    oh ok. minsan style sa banawe dalhin mo ung part, or kung meron ka picture then pahanap ka sa runners, meron lang sila tubo compared kung ikaw maghahanap pero it never failed on me, katakot lang minsan baka di ibalik ung pyesa hehe, kya baka pwede picture lang.
    good luck
    Jun 2004
    #5117
    good luck
    Jun 2004
    #5118
    good luck
    Jun 2004
    #5119
    sensya na sa triple, nag eerror eh
    Aug 2005
    #5120
    Techconnect, Sir ito suggestions ko:
    1. Not because may ilaw ay okay. you may try your horn kung sakal (ignition key is at "on" position). How about the connection sa battery terminals? Ilang months na battery?
    1.1 Set all the electrical loads (light, stereo, indoor lamps to off) try to start and check the response.
    1.2 Try to borrow a similar type (e.g. 3SM, 2SM) working battery and see if ganun pa rin response
    1.3 Have the battery checked sa batt shop.
    2. See Sir PB's comments on glow plugs.
    3. Fuel line/ pump. Check if may water sa filter. Nag ilaw ba indicator? baka may halong tubig na sa line mo kaya parang palyado. You may bleed the fuel filter. It happened na sa ride ko, observation ko parang sakal and ramdam mo drop sa hatak.
    4. All emergency check up done at di pa rin nag work, then bring it to a mechanic na.
    Naway may natulong po sa inyo.
