Page 507 of 660 FirstFirst ... 407457497503504505506507508509510511517557607 ... LastLast
Results 5,061 to 5,070 of 6591
    Mar 2003
    #5061
    door tok tok sound pag nalulubak, door hinge problem saakin, but kasalanan ko kaya nasira ko kasi nasobrahan ko ng bigat yung doors ko dahil sa deadening and speaker.
    to check kung sira hinge niyo, open door and lift door from bottom and listen for tok sound sa hinge mismo kung upper or lower. di naman kailangan bumili ng bago pinapa machine shop lang, lalagyan ng shim. P400 lang. pinagawa ko rin yung luma but binili ko lang bago kasi para mas tumagal dahil naka deadening inner and outer shell plus yung interior door trim, kaya 3 layers yun. iba na tunog ng door ko pag sinasara sa bigat. ang masama lang hindi painted pag bago.
    tdiesel4d56, di yata normal yun. di ko napansin na ganun yung gen 2 namin.
    #5062
    sir pb.. saan saan po kayo nag deadening? all 5 doors? what about ceiling? diy po ba yan? did you use flashband? plan ko kasi deadening siyempre diy(no choice.. no budget).. hehe
    Jun 2004
    #5063
    Quote Originally Posted by AC View Post
    makikisingit hehe. you can deaden all doors, pwede inner lang pero tyagaan sa DIY. ganda bagsak ng door mo. look for deadening mats para mas madali at malaki agad coverage.
    ceiling? ginagawa din ng audio freaks ito pero sa magazines ko lang nakikita. siguro better ang roof insulation pag sa ceiling, mas madali ikabit pero mahirap DIY kasi meron mga braces ang ceiling. pero kaw pa
    Nov 2006
    #5064
    Quote Originally Posted by archijardy View Post
    you can try the rubber stoppers on your doors (bottom part) or the plastic/rubber thingy on your strikers/door catch. or try door alignment.
    good luck!
    i will try to check this.thanks. pag hindi nag ok, meron ba kelangan sikipan sa loob ng pinto? sa hinge ba pinapalitan din yung parang pampasikip sa shaft?
    thanks
    May 2008
    #5065
    Good morning FMers. Tanong lang, yung lock ng rear door kasi hindi sumasabay sa power locks. Kailangan pang gamitan ng susi para bumukas. Magkano kaya paayos 'to? Sabi ng friend ko sakit daw talaga 'to ng pajero.
    Oct 2009
    #5066
    repicheep, go for rp ka na. hindi ka magsisisi sa paggamit nun.
    as kung sa speedlab o speedyfix, sa speedyfix kasi ako nagpa-change oil nung january. hindi ko lang alam sa speedlab kung ganun din ang pricing nila at ang service nila. pero sabi ng iba, ok lang ke speedlab. pero either of the two, masasabi ko lang, madami kang makikita sa loob, mga nagagandahang kotse :drool:
    testa, sige try ko din sa speedlab, malapit lang dito sa amin. gusto ko din malaman yun rp oil na yan. anu ba rating nyan 10W-50?
    bros, may alam ba kyo mura bilihan ng gulong dito sa banawe-west ave. area na trustworthy at di peke binebenta? napunit yun gulong ko sa sidewall while going to my hometown in tarlac last oct31. badtrip dahil 1st time ko lang na-flat sa kalsada in all my driving years. gusto ko sana mag-upgrade to rim 18" from the stock 15".
    eto na lang ang luho ko, hehe, pero mukhang mapapasubo yata ko dito ah...
    #5067
    thanks sir archi.. hehe
    additional question nadin po ako sainyo..
    pag.. hindi naman sasali sa sound-off competition.. mga pang araw araw lang ano po suggest niyong i deaden ko? for daily drive lang sana.. front doors only? 4 doors? 5doors? or 3doors(2 sa front and back door)? should i deaden only outer? inner? or both? pasensya na.. wala ako alam sa ganyan.. hehe kaya dami tanong.. sa amin po gen2... wala kaming speaker sa front doors.. speaker namin nasa dash lang.. sadly... only 4" speakers fit ... im planning to make speaker holders sa doors... for my new seps... 5.25inch.. 2 years na nasakin.. wala lang ako panahon mag kalikot.. hehe
    sir reepicheep..
    nasira po actuator ng door ko last month... rear driver side.. 6t+ daw original niyan... taiwan replacement 350... kayalang... its better to get the original fixed daw... since iba ang design ng taiwan... gagawan pa nila special bracket and baka magka complication pa ang sa sunod na problema.. hehe
    eventually i got mine fixed... yung gumawa sakin 200 lang siningil... may nabali lang daw sa loob...
    btw yung akin... hindi naguunlock... but pag unlocked siya naglolock naman... and pag... nag uunlock ako.. and nagfafail siya meron loud buzz...
    Mar 2003
    #5068
    Ac, sa akin front doors lang and tailgate, all flooring, then yung buong 3rd row form ceiling to floor kasi nandoon ang sub ko. diy lang yan di naman mahirap. for everyday driving siguro sahig and ceiling nalang. double yung layer sa wheel wells. maganda rin siguro lagyan yung fender liner na plastic sa front wheels. just dont expect too much, mababawasan but not eliminate noise.
    May 2008
    #5069
    sir reepicheep..
    Woops wait, i'm talking about the rear door as in yung trunk door. Sorry for the misunderstanding haha.
    #5070
    sir vacs, rating ng 4m40 natin is 15w-40
