Results 4,791 to 4,800 of 6591
September 29th, 2009 10:59 PM #4791
garci, may idea na ako gaano kalalim,
AT ecu nga yung katabi ng fuse box. almost ka level na siguro ng upuan natin yung tubig. yung blower motor ng aircon nabasa rin siguro and yung control box ng airbag natin and power seats and motors, nasa likod ng cigarete outlet sa baba ng radio yung airbag electronics. radio mo siguro di na inabot. pasensya na dami tanong, gusto ko kasi malaman which elctronics ang tatamaan, nasa to do list ko na itaas ang mounting ng AT ecu.
swerte rin yung mga naka manual na pajero wala silang ecu ng AT.Last edited by promdiboy; September 29th, 2009 at 11:01 PM.
September 29th, 2009 11:46 PM #4792
hello po newbie po ako here. binaha po un 3dr pajero ko un japan galing. umabot hangang headlight medyo mga 3 hrs cguro sya nababad. tapos umandar naman nun pna chk ko sa mekaniko. i had it checked kasi ngloko power window ko then napansin ko un umiinit un sa likuran un heater ata un. SAN PO BA PINKA OK NA PDE PA CHK ELECTRICAL NUN KASI MALAMNG NAAPEKTUHAN DAHIL PUMASOK UN BAHA NUN SAT.ano po ba dapat kung gawin not familiar kasi sa mga sasakyan.
UN POWER WINDOW NA REPAIR KNINA PERO NA AUTO UNLOCK PAG PINATAY NA MAKINA TPOS PAG ILOCK NA AYAW NA GUMANA. PLEASE HELP
September 29th, 2009 11:50 PM #4793
September 29th, 2009 11:55 PM #4794
Pareho ata nangyari sa amen ni garci. Yun blower ata sa likod na upuan un parang nag cause ng init sa loob. Ano po dapat gawin help po
September 29th, 2009 11:59 PM #4795
ang problem ko pa po ngaun kung san sya pwede ipagawa kasi lahat punuan ang pagawaan
September 30th, 2009 12:03 AM #4796
The electricals are still wet with water and causing some things malfunction by not working or working when you don't want it to run. The only way is to dry everything out. Unfortunately with the long backlog at the casa and auto service centers, it might be a long wait.
You can try asking for help at Goodyear Servitek shops or at SPEEDLAB or at SPEEDYFIX.
Speedlab is located along Quezon Ave.
Contact info: http://www.speedlab.com.ph
Speedfix is located along Shaw Bvld.
Contact info: http://www.speedyfixph.com
No guarantees if they can accept your vehicle for servicing until a week from now though.
September 30th, 2009 12:08 AM #4797
3 na po yun napuntahan ko kanina yun kahabaan nga po ng banawe nag try ako pero talgang punuan. delikado ba yun kasi ng sm ako kanina pag pasok ko napansin ko mainit yun blower ata pero na ka off naman. hinde ko alam kung bakit sya ng iinit. tommorrow papalinis ko yun loob sobrang nabasa kasi pati upuan
September 30th, 2009 12:13 AM #4798
From how you describe it, it might be the heater coil running without the fan. It might be dangerous because it might start a fire inside the vehicle if the heating element or whatever is shorting out due to the water starts to smolder into a flame.
BTW, one place to avoid is RAPIDE. Too many horror stories already.
September 30th, 2009 12:17 AM #4799
msdriver, I strongly suggest you disconnect the battery and look for the part na umiinit, it seems may nagshoshort, baka bigla nalang may magliyab. wala bang pumuputok na fuse kasi dapat pag may nagshort fuse mauuna. unless yung wiring mo pinalitan ang linya during the conversion.
September 30th, 2009 12:21 AM #4800
inopen ko po muna yun window para hinde makulong yun init sa loob. hindi ko po kasi alam tanggalin un battery.
tom dalin ko sya ulit sa pinagbilan ko baka macheck nila pati yun conversion.
