Results 4,741 to 4,750 of 6591
- Nov 2007
- 33
September 24th, 2009 03:23 PM #4741http://www.auto-searchphilippines.co...on_Cluster.jpg
sir anong tawag nung nasa gitna nito? sira na kasi yung ganyan ko.. magkano kaya yung ganyan
- Nov 2006
- 338
September 24th, 2009 08:28 PM #4742
- Oct 2007
- 120
September 24th, 2009 10:02 PM #4743Hi Pajero Peeps;
Let me tell you about my pre-owned newly acquired Pajero. It's a 2003 Fieldmaster 4X2 Ralliart edition w/ 31K on the odo. Pinakita ko na kay Joseph Atutubo & my suking mechanic. Pareho sila ng opinion na pwedeng tama yung odo after inspecting the unit. So far ito na ang nagawa ko these past 2 weeks, basically change all fluids 1] Change oil - Petron Trekker & Vic oil filter 2] Change ATF & power steering fluid - Unioil ATF Dexron II dahil ito yung gamit ng casa dito sa makati. 3] Change coolant - Unioil long life coolant - ito rin ang gamit ng casa - green yung color. 4] Change Brake fluid - Caltex DOT3. Sa ATF Dexron II gamit ko dahil ito yung specs sa manual & sa hood sticker. Pero mi nabasa rin ako na Dexron III pwede rin dahil backward compatible. I did not drain and change the rear differential & transfer case gear oil dahil malinaw pa nung binuksan. kahit yung brake fluid & power steering fluid konti lang ang dumi. I had the brakes cleaned & inspected - ok pa ang rear brake pads, pero pinapalitan ko na yung front brake pads ng OEM 3.5k sa la brava taft ave., dahil mas manipis na at hindi na siguro rin magtagal at nabuksan narin eh. In your experience ilang kms ba ang life ng OEM front brake pads? Basa yung front passenger carpet & I brought it sa aircon shop sa The Fort at yun drainhose lang pala hindi naka kabit ng maayos. Sabi rin ng aircon tech bantayan ko raw yung aux fan ng aircon ko. I plan to change motor oil every 4k dahil sa stop & go driving dito sa Maynila. So far so good & I'm happy with my Pajero FM. Mas madalas nyo na akong makita rito & hope it's ok w/ you guys.
September 24th, 2009 10:17 PM #4744
ganun po ba idol pb? ang saket naman sa bangs...gastos na naman, hayz!...idol baka po mayron kayong mairefer na reputable shop for calibrate na medyo mura, medyo tight po kasi budget ko ngaun..and ang "tug" sounds naman, hindi po kaya shock shift un? may nabasa po kasi akong isang thread dito, na medyo similar sa remedy ko...
September 24th, 2009 10:21 PM #4745
- Aug 2006
- 121
September 24th, 2009 10:41 PM #4746I was about to start the car and go home na sana, kaso biglang ayaw magcrank. nagcrank and nagstart naman siya after a few tries, scenario is umiilaw naman lahat ng lights at indicator, ayaw lang magcrannkk pero suddenly after putting the key in start and after 2 seconds nagcrank na siya.
para siyang matic na walang crank pag nakalagay sa D
pagdating ko sa bahay nagstart naman siya ulit nung pinatay ko,
Kanina umaga ok naman ang start ko.
ano po kaya ang problem mga sir's?
Thanks
- Nov 2006
- 338
September 24th, 2009 10:51 PM #4747hay buhay! hard starting nanaman ako pag matagal na napahinga FM ko. kapag pauwe na ko from work hirap start. pag umaga mga 2 times dapat. Newly replaced 3 glowplugs ng HKT-PM165. Mukang bumigay din. 1 month lang tinagal. will verify tom. Pero yung natitira kong isang OEM, buhay pa din.
Sang shop ba mura ang OEM glow plugs naten? and ano real price nito? bili ko dati 1.8K each lang. yung iba shop ngayun 2.5K daw. mukang tinataga na din eh...
recommendations naman mga paps...
thanks
September 24th, 2009 11:50 PM #4748
sir AR.. i got mine sa commuter... 1100 yata or 1200
glowplugs... commuter nasa masangkay between soler and recto.. look for vic.. very accomodating.. sabihin niyo nalang nirefer ni mighty
September 25th, 2009 12:36 AM #4749
razor360, saan ang place mo? May nabasa ako from this thread na magaling na shop sa marcos Highway at reasonable price. sa Taytay Rizal ako nag pa calibrate plus palit ng injectors umabot lang sa akin ng 12K pero last year pa iyun. ang name ng shop ay BAL Diesel calibration center.
September 25th, 2009 01:19 AM #4750
ar, yung pang lancer lang gamit ko, nung naluma prone sa moisture yung lens and faded na yung chrome reflector, though nilusong ko siya sa baha at nalubog talaga siya nitong huling bagyo lang,
overall ok na naman na ako sa lancer replacement.
17m, congrats on your new pajero, saakin oem brake pads ko pinapalitan ko every 50k kms, mga 1/8" nalang naiwan sa harap. sabay ko na pinalitan harap at likod.
igixxi, inclinometer tawag diyan, katagalan nagleak yung oil niyan, silipin mo yung pics ni AC ng DIY reapair niya. nandito yung sa thread natin.
razor, pagawa mo na yan, kasi pag pinipilit bombahin yung makina para mag start pakiramdam ko may nasisira sa makina, grabe yung palag at usok, baka may madamay pang iba, cant help you kung saan mura, promdi kasi ako. gudluck sa pajero mo
repair kit lang. car care nut says, for toyotas, he recommends entire assembly replacement for...
rack and pinion repair
