Results 4,721 to 4,730 of 6591
- Nov 2008
- 81
September 23rd, 2009 10:23 AM #4721pb,ganda idea mo sa always on dash lights,pag nadale mo please share and post,medyo malabo na rin mata ko tapos may reflection pa, tks a lot!
- Nov 2006
- 338
September 23rd, 2009 10:55 AM #4722mga paps,
sang shop affordable ang foglights ng FM nten? I heard pang lancer daw nilalagay ng iba. is this true? or better yung orig talaga? san po meron? khet surplus basta orig.
also orig na rain-guards....
thanks po...
- Apr 2009
- 15
September 23rd, 2009 12:28 PM #4723mga guru makikisingit lang po, ang problem ko kasi yun pajero ko kumakain ng langis, binaba na yun makina at complete overhaul, tapos pinacalibrate narin po palit injection pump at nozzle, pero kumakain parin ng langis. sabi ng mekaniko kinakain naman daw ng turbo ko kasi nun pinacalibrated at tinanggal yun turbo me nakita mga langis. Parang nanghuhula na lang tong mekaniko na nakuha ko eh, ano pa po ba pede macheck kung bakit kumakain ng langis ride ko thanks po sa mga magrereply.
September 23rd, 2009 02:17 PM #4724
Meron, kainlangan ito sa auto start kaya lang hindi ko matandaan kung ano doon. Kinapa ng nag install yun sa mga wires sa panel.
Ok yung naka on yung LED pag nag on yung engine. Hindi naman malakas sa kuryente itong LED so no problem. Tanong tanong ako kung sino marunnong nito.
September 23rd, 2009 02:37 PM #4725
pr462 nelany, pwede masabay sa on yung dash lights, isang wire lang naman. yung socket black na mahaba. nasa likod ng speedometer. upper socket. 5th wire from right. kulay green wire. test light mo sa parklights. then cut and kabit mo sa ignition wires. oh yeah fuse dont forget.
ar, pwede lancer fogs, 3,500 to 4k ang price. sa jaffas or procars sa banawe meron.
September 23rd, 2009 06:19 PM #4726
Sir promdi, sorry for the delay of the pictures. Gabi na kasi ako umuuwi kaya hindi ko makuhanan. I'll take shots and post them here 'pag may time.
- Aug 2009
- 11
September 23rd, 2009 06:22 PM #4727Gentlemen,
Consult lang ako ulit. Kalampag problem. Unit ko is a 5-dr. Pajero 2.8 Subic Model. Napanisin ko malakas na yung rattle ng front axle ko, especially when driving in bad roads, like EDSA. So my initial suspect are bushings in the front axle.
So I had it checked this July on three shops here at QC to know what's the problem (forgive me if my terms are not that accurate, Im not too familiar with under chassis parts):
1) GTS (Congressional)
replace upper/lower ball joints, front axle bearings, pitman arm, tie rod ends, bushings...etc. --->PhP12,000+ (parts and labor)
2) Servitek (Timog)
replace upper/lower ball joints, front axle bearings, transmission support parts, rear axle bushings, and many more --->PhP25,000+ (parts and labor)
3) Cruven (Crame)
replace upper/lower ball joints, pitman arm, tire rod end, bushings. --->PhP6,000+ (parts and labor)
However, last weekend, I had a repair job from a trusted mechanic...and replaced my front axle bearings (left and right)..NTN brand. Medyo nabawasan yung malakas na kalampag. My expenses...PhP3,500. I've shown the quotation from the three shops, Sabi nia, oks pa naman daw un ibang parts, no need to replace.
Kaso, may konti pa ren ako na-fe-feel pag nadadaan sa malalim ng lubak, lalo na pag aroung 40kph+ ang takbo. Di kaya yung mga tie rod, ball joints and bushings e kelangan ko na ren palitan? Or baka yung bullbar naman yung possible suspect? How about transmission or engine supports, possible ba?
Your opinions and suggestions are very much welcomed...Thanks and have a safe drive.
- Nov 2006
- 338
September 23rd, 2009 08:42 PM #4729
September 23rd, 2009 09:07 PM #4730
Pinaka magandang gawin mo humingi ka ng second opinion sa ibang reliable na mekaniko na bihasa sa makina ng Pajero mo . Para may idea ka kung tama ba ang ginagawa ng mekaniko mo . Kasi iyong iba trial and error hanggang lumaki gastos mo ng hindi nagagawa ang problema ng sasakyan. Tol suggestion lang.
How about 97 LXi?
Civic horsepower
