Results 4,611 to 4,620 of 6591
September 12th, 2009 09:08 PM #4611
mr. lucky023, try replacing your ATF first. check your atf kung pinkish pa ang kulay and hindi amoy sunog.
September 12th, 2009 11:55 PM #4612
Anyone here with a DIYed/aftermarket grounding kit? Could you post pictures where you exactly positioned the connectors (Just making sure not to mess up my system)? I'm planning to DIY one for my '99 FM. Heard it really improves electrical flow on aged vehicles.
Also, if my ride has grounding kit already, would I still need the big 3 upgrade?
September 13th, 2009 12:36 AM #4613
reepicheep, page 169 may pics ako ng grounding kit ko, ang di ko lang nakunan diyan yung pinakamahaba pumunta sa auto tranny.
ang kulang nalang sa big 3 is alternator to battery, I used gauge 4 wire with fuse 125amps agu fuse near the battery.
yung dalawa kasama na sa grounding kit, negative to chassis and negative to engine.Last edited by promdiboy; September 13th, 2009 at 01:02 AM.
September 13th, 2009 01:44 AM #4614
September 13th, 2009 11:17 AM #4615
Thank you very much sir. Also, could you sir post a picture of your gauge 4 wire and fuse? Where can i buy those?
My ride sir is bone stock. And this is my very very first car. Kaya i'm not sure pa to stick the wires. Heck, I don't even know what the alternator and turbo shielding looks like until i saw your picsCan i just pattern my with yours?
So basically. I need a kit with eight 8 gauge wires, better battery clamps to accommodate all the cables and a guage-4 cable.
From (-) terminal:
2 should go to: body (one to the stock grounding -- where is this?; one near to the fusebox -- is this the place where strut bars are usually bolted on? )
1 to the tranny
2 to the front bumper (grounding points of horn and headlights -- i only see one in the pictures, where should i bolt the other one to?)
1 to engine (valve cover)
From engine:
1 to body (can i just bolt this on the valve cover along with the cable coming from the battery?)
From alternator bracket:
1 to body (can i just bolt this to the same place where the engine-to-body cable is mounted?)
Thanks again for helping a newbie.
September 13th, 2009 03:00 PM #4616
mga sir.. tanong lang po... pano malalaman kung busted na ang turbo ng 4d56? just curious.. dumaan kasi ako sa turbo shop.. dami nagpapagawa.. napaisip lang ako... 11 yrs na yung akin... ayos pa kaya? hehehe
- Nov 2006
- 338
September 13th, 2009 04:43 PM #4617finally, had my glow plugs replaced with KHT PM-165. It works nga..and my antenna replaced also...yipee!!
question, meron bang right side mirror (yung nilalagay sa may hood) for our FM? meron nabibili sa mga malls pero baka lang meron talaga JDM na para talaga sa FM nten. let me know.
thanks
September 13th, 2009 10:09 PM #4618
reepicheep, heres my batt to alt positive connection,
yung wire na pataas ang papunta sa batt. wrapped in plastic moulding para oem look.
heto naman yung fuse, yung isa pumunta sa amps, then yung isa sa alt.
September 13th, 2009 11:14 PM #4619
Nice sir. Thanks a lot. Btw, are your wires branded? Where did you buy them including the fuse holder? How much?
September 14th, 2009 12:02 AM #4620
reep, its scoche efx brand. 80 per feet dito probinsya, matbe alot cheaper sa manila. mga 15 feet siguro inabot saakin, yung fuse holder is 800 yata. efx din
