Page 461 of 660 FirstFirst ... 361411451457458459460461462463464465471511561 ... LastLast
Results 4,601 to 4,610 of 6591
    Apr 2008
    #4601
    tnx testy ad sir PB sa reply.
    Mar 2003
    #4602
    testy, sa injection pump and injector banda ang difference natin, dapat may electronics na yung sa inyo. hanapin ko yung article na nabasa ko about specs ng inyo,
    eto galing wikepedia 4m40
    4M40
    * Engine type — Inline 4 cylinder SOHC
    * Displacement — 2835 cc
    * Bore — 95 mm
    * Stroke — 100 mm
    * Fuel type — Diesel
    Intercooled turbo
    * Fuel system — Distributor type injection pump
    * Compression ratio — 21:1
    * Power — 92 kW (125 PS) at 4000 rpm
    * Torque — 294 N·m (217 lb·ft) at 2000 rpm
    Intercooled turbo
    * Fuel system — Electronic control type distribution type jet pump
    * Power — 103 kW (140 PS) at 4000 rpm
    * Torque — 314 N·m (232 lb·ft) at 2000 rpm
    yung 2nd ang local yung 3rd ang jdm.
    #4603
    Bro PB,
    maraming salamat sa quick reply RE: LED lights. I checked page 260, the one you told me, lahat ba ng led lighys mo, galing pa abroad [states]?
    Hindi ba available locally ito sir?
    maraming salamat and more [horse] power...
    Aug 2007
    #4604
    Quote Originally Posted by pr462 View Post
    ikawngaba sir, thank you for pointing me to the page, tanong ko lang gaano katagal inabot pagpapalit mo nito?salamat
    sandali lang magpalit nyan matagal pa ang ipaghihintay mo kapag tinanghali ka ng punta doon, kaya dapat maaga ka pumunta para wala pa gaano kustomer.
    wala pa 1 oras yan.
    Mar 2003
    #4605
    to further lessen the road noise sa cabin, I placed a rubber mat na nabibili lang sa suking canvass stores, this will be sandwiched between the floor and the carpet. im just not sure kung effective. more material to block noise from coming in. mga 3/8 ang kapal ng mat.
    rlx555, meron din leds available locally.
    Jun 2009
    #4606
    Foggy Dashboard??
    Hi, nagpalit ako ng several peanut bulbs sa dash board panel & all burning well, but the problem is since I boxed up the panels, every morning condensation is taking place on the plastic cover of the panel which blurring the face displays of the instruments. Wala naman akong natatandaan na tinangal na mga rubber or silicon sealant. During long run dahan dahan din na nawawala. Have you experienced this? & what corrective action ang ginawa ninyo. for sure this is cause by cooler air seeping in.
    Thanks-RTS
    Mar 2003
    #4607
    rts, nangyari saakin dati yan. yung ducts ng aircon yan sa likod ng gauges, im guessing nasa upper right corner siya, either yung foams sa connection ng ducts napulbos na or natulak ng wires yung ducts nung binalik mo gauge kaya nabuka yung duct. kung saan banda yung moisture doon yung leak. i used aerotape(yung ginagamit sa aircon pang insulate) sa mga exposed ducts. and matagal ko na di nakita uli. remove the gauge and turn on your aircon to check.
    May 2008
    #4608
    I've finally changed my headlight bulbs to Philips Xtreme Power and visibility improved a lot. However, I still find night driving better with my CRV (also on XPs). Sa headlight reflectors na kaya to?
    Dec 2008
    #4609
    good afternoon pajero owners.. i have question regarding automatic transmission. i have my gen 2 pajero changed its oil and filter yesterday, valve cover gasket was changed, fuel and air filter was replaced with a new one too. but after all the work was done and when im about to start the car, the "a/t" on the dashboard keeps on blinking until today. i just used the car a while ago and it seems everything is ok.
    now my question is, what causes the "a/t" to blink? and does replacing the filters and oil has something to do with it?
    btw, my engine was calibrated last saturday. they replaced all the nozzle tips with a brand new one and injection pump was calibrated as well. and automatic transmission fluid was changed last month.
    need your inputs guys. any help would be much appreciated. tia!
    Dec 2008
    #4610
    btw, its a 2.8L pajero from subic (3 door) and the engine is 4m40.
