Page 458 of 660 FirstFirst ... 358408448454455456457458459460461462468508558 ... LastLast
Results 4,571 to 4,580 of 6591
    May 2008
    #4571
    Quote Originally Posted by AC View Post
    i just got my paj some goodies:D
    yehey... pacheck ko muna relay bago install.. baka masira lang agad eh..
    any electricians you guys can suggest near qc/malabon? wag lang wizard.. had very bad experience from them
    May suking electrician si Doc Otep sa banawe. Jameson, malapit daw sa Sogo yung pwesto niya. 09215711924
    #4572
    salamat po sir reep...
    freelancer po ba siya? hanapin ko nalang po? jameson? thanks.. mahal po kaya magpacheck/install ng glowplugs? magkano kaya? hehe
    #4573
    Pajero Brothers,
    Effective ang discovery ni bro TAZ 13 - Starex Antenna rod [ gear type].
    I got mine here in Pampanga at P400 and P200 for labor, so total of P600 lang gumagana na ulit ang power antenna ko. BRAVO TAZ13! This indeed is one great discovery, this is the most practical solution to the sky-rocketing price of the "casa" at 14k for the antenna assembly.
    Please continue to share your "practical" antedote to the usual pajero problems we are encountering.
    SIR PB,
    bro, if it would not be too much to ask can you pls PM me the complete list of LED lights na inilagay mo sa ride mo, I'm interested with this project kasi sir.
    Thanks and more power! EB naman tayo mga ka- paj...
    Mar 2003
    #4574
    si jameson ang nagkabit ng foglamps ko dati.
    sa repairs marami din ako nababasa na good remarks sa speedyfix. masipag siya mag reply. di naman ganun ka complex ang GP natin. test light lang kailngan para matrace kung stuck or sira ang relay. 4m40 talaga mabilis masiraan ng glow plugs.
    Mar 2003
    #4575
    rlx555, nasa page 260 yung led types.
    saludo din ako sa findings ni taz13, mura talaga.
    #4576
    pwede po ba diy test ang relay ng... glowplugs?
    pag turn ng susi(using tester)... gumagana 12v+ ng glowplug ko for around 3 to 4 seconds... is that enough of a test? sabi kasi pag sira daw relay.. and bago ang glowplugs... masisira din glowplugs kaya nanhihinayang ako.. kayalang... hindi ko po alam kung saan may electrician very familiar.. with glowplugs.. takot kasi ako baka... test test.. hindi pala marunong.. hehe like yung sa wizard.. yung electrician.. di gumagamit ng tester... hehe...
    Aug 2007
    #4577
    Quote Originally Posted by pr462 View Post
    gents, tanong lang ako meron na ba sa inyo na nagpapalit ng torsion bar bushing ng pajero. 4x4 kasi sa akin at kumakalampag na yung bushing na nakahawak sa differential sa harap? magkano kaya ang piyesa? assembly ba ito o puede ba yung bushing lang palitan and magkano kaya?thanks for any information you can provide
    Sir, please backread sa page235 re sa torsion bar collar bushing, sa motorix meron nyan 80pesos ea dati ewan ko lang ngayun, 4 kailangan mo. Doon mo na rin papalitan.
    Mar 2003
    #4578
    AC, tama nung inobserve ko, pag on ng preheat light Gp will work mga 5 secs kahit 2 secs lang patay nanpreheat light , then TIK patay, pag nag start and malamig engine gagana uli gp hanggang maginit maririnig mo uli tik. mga 30 secs ng driving. but pag mainit na makina mo di na gagana gp kahit sa on palang.
    ikawngaba, sorry my mistake meron palang bushing, yan ba yung plastic part sa dulo? di ko pa pinapalitan yung akin, di ko napansin na may wear nung kinalas torsion bar ko.
    Jun 2009
    #4579
    Quote Originally Posted by TAZ13 View Post
    Sir ask ko lang kung magkano yung relay at sensor? paano inayos yung timing? meron ba pinalitan na part for the timing? kamusta na ride nyo? tnx sir
    *TAZ13
    Sensor about P340+ this one is located at engine block w/c sense water temp.
    Relay is the onewith in the starter assembly or sometimes they called it diaphram this about P 400.Timing is just series of test & wiring attachement done by the electrician.
    Im not 100 percent satisfied dahil it need some time pull the chock, but one start lang sya. I think the lamp for heater is normal quick extinguish mode.
    Still under observation, I will wait for one week'presently better than before ang starting.
    RTS
    May 2008
    #4580
    God, I just hit a concrete barrier, breaking a hook under my rear stepboard. Now it's misaligned, magkano ba surplus nito?
