Results 4,531 to 4,540 of 6591
September 8th, 2009 05:33 AM #4531
rlx555, sa casa ko na inorder, 1 month bago ko natanggap by order kasi, mga 8 hours ko siguro kinalas and binalik. first time ko kinalas kaya hinanap ko pa mga screw points. socket wrench lang kailangan mo and a screw driver tsaka rubbing alcohol narin dahil sigurado masususgatan ka sa kakadukot.
jhong, imho invest ka sa oem na engine support, AT (auto) kasi akin, pag bagong lagay yung AT support ko hindi bagsak yung TC (transfer case) support ko, nasa gitna siya but after a month bababa rin siya. pag supports oem na kunin mo,
janrye, kamusta ang buga ng HID fogs mo?Last edited by promdiboy; September 8th, 2009 at 05:52 AM.
September 8th, 2009 02:19 PM #4532
peterson, welcome to tsikot, :hi::hi::hi::hi::hi: how did you test kung sira na glowplugs? do you still here the tick sound after mamatay yung heater light?
- Nov 2006
- 338
September 8th, 2009 02:21 PM #4533mga paps,
i am having problem starting up engine sa umaga. Found out na hindi na gumagana yung 3 heater plugs. Replaced them already. But still ganon pa din. Napansin ko mabilis mag shut-off yung heater indicator sa panels. Sabe ng mechanic ko baka daw sa electronic control ng heater plugs. San pede magpagawa ng ganito? and how much kaya pag palitan?
any inputs guys?
salamat po....
September 8th, 2009 04:25 PM #4534
guys,
pwede ba or meron na nakagawa sa inyo ng mod na may "on/off" switch ang power antenna natin, yung switch na gagamitin yung mast switch?
nagpalit lang kasi friend ko ng power antenna assembly niya eh ayaw na niya lagi tumataas yun kahit naka cd/aux mode yung HU.... para gagamitin lang kapag naka tuner. pioneer kasi HU niya kaya kahit naka cd/aux nakataas pa rin antenna. (or may mali lang na connection?!? i heard ganun talaga raw mga pioneer?!?)
btw, out of curiosity lang tumawag kami sa casa nasa 13k plus ang power antenna assembly (motor with rod etc) kaya dun na lang kami sa replacement 1200k pati labor na.hehe thanks
- Nov 2006
- 338
September 8th, 2009 05:37 PM #4535
September 8th, 2009 05:48 PM #4536
Glow Plug???
Three weeks ago I replaced my 4glow plug due to hard starting every morning, sabi noong electrician kailangan palitan including the sensor. Matapos palitan I was happy dahil morning sickness gone, but after three days balik na naman. Yesterday dahil walang pasok I brought the PJRO to the electrician , this one another person. Again the 4 glow plug are "kaput" I told him that recently it was replaced, so he go extensive probing & found out the following are defective(1) Relay of starter, (2) Timer of the Glow plug offset(3) glow plugs busted,(4) sensor pinalitan din. This morning starting okey, but I can't say yet that the problem is already solved,will be observing for 1 week sana nga natumbok na ang problema.
RTS
September 8th, 2009 07:31 PM #4538
sir ar24458
may nagturo po dito before...
na pwede gamitin antenna ng starex...
may stock sa apic parts.. nagbebenta po ng korean parts for 350 pesos
telephone number 7129108
wag niyo nalang sabihin sa pajero niyo gagamitin... para di nila taasan price.. 2t po kasi pag original pang pajero..
then pakabit niyo nalang sa banawe.. around 300php pataas..
btw apic is in banawe...
mas mura sa hybrid and seiring kayalang wala sila stock eh.. hehe
320 and 300 yata dun.. hope this helps
yung tip lang difference from pajero after install.. but looks fine naman..
September 9th, 2009 12:28 AM #4539
GLOW PLUGS and Antenna Rod
Yan din ang problema ko, 1 month after ko magpalit ng glow plugs and relay, hard starting na naman kanina umaga, lakas kasi ng ulan mag hapon eh.
ano kaya cause ng pakakasira agad ng glow plugs ko? OEM na lang siguro kukunin ko next time, kaso baka masira ulit, butas ang wallet ko.
Antenna rod- di pa ako nakakaluwas ng Banawe for the starex rod replacement. yan talaga ang balak kong bilhin kapag may free time.
Lastly, saan kaya maganda magpa wrap ng leather sa steering wheel, preferrably sa banawe area din, mga how much kaya? sabay ko na rin leather seat cover medyo worn out na rin yung sa akin eh.
Thanks mga ka paj.
September 9th, 2009 12:57 AM #4540
yung sa akin kasi motor na mismo ang sira... so assembly na pinalit namin... motor/rod/etc (isang box naman yun)... replacement lang kinuha namin kasi ginto ang presyo ng original... sa sun x kami nagpapalit ng power antenna, sa autocentro sa araneta cubao... bale P1,200 lahat kasama na labor. mga 30min lang ginawa ok na.
repair kit lang. car care nut says, for toyotas, he recommends entire assembly replacement for...
rack and pinion repair
