Results 4,501 to 4,510 of 6591
September 6th, 2009 07:29 AM #4502
AC,
suggest ko lang, go gey new original glowplugs that cost over 1k each, yun, and tumatagal, the cheap ones are not durable, and baka masira pa starter mo sa kakaclick mo, masmagastos pa yun pang nasira....naexperience ko na yun when i had my gen 2, believe me, it is worth it getting oem glowplugs sa gen2 mo. years mo magagamit yan na one click lang.
September 6th, 2009 10:42 AM #4503
oo nagdala ako pb pero ginawa kong reference number eh yun pinakita mo sa akin. so far so good, at masaya ako na lahat ng ilaw sa panel board ko gumagana na. nagmukha tuloy bagong bago na ang interior ng sasakyan ko
- Aug 2006
- 121
September 6th, 2009 03:32 PM #4504sir' I have questions, I had my gauges' bulb checked yesterday, pinapaltan ko na rin yung bulbs, problem is yung sa oil indcator di na kasi umiilaw pero di daw busted. would you know po mga sirs kung san located yung sensor? could be the sensor daw.
also, kanina 2am lakas ng ulan and baha, mejo nababasa po yung mga sensors e umiilaw po yung ibang indicator, alam nyo po ba kung san located ng mga sensors and kung pedeng gawan ng paraan na matakpan sila and hindi mabasa.
di naman ganun kataas yung water at mabagal lang din yung takabo
Or dahan dahan na lang magdrive sa baha, kaso worried lang ako baka lang ang ganitong may case
- Nov 2007
- 33
September 6th, 2009 05:42 PM #4505Good afternoon,
what engine oil would you prefer for my pajero gen 2 4d56t? royal purple? delo gold?
do i need to change my fuel filter every 5,000kms?
- Apr 2009
- 3
September 6th, 2009 05:53 PM #4506sir tanong lang po ako kung paano maalis yung vibration nag aking pajero 1996 model manual transmission. nagpalit na po ako ng transmission support at trans support pero meron pa rin vibration. patulong naman po.thanks
Tsikot Member Rank 1
- Jul 2009
- 4,090
September 6th, 2009 08:11 PM #4507why not go for blings like mine? i installed a 26" rims on my fieldmaster.
September 6th, 2009 10:40 PM #4509
vinkim, ang oil sending unit ng 4m40 nasa likod ng radiator, in between the power steering pump and valve cover. para siyang tansan na may naka dikit na single wire sa dulo, baka na disconnect lang yung wire. mura lang yan parang 150 lang yata kung tama alala ko. pag umiilaw warning lights mo sabay sabay nabasa alternator mo. nangyari lang saakin yan nung lumusong ako ng malalim sa dapitan. once palang yun, di kaya may natanggal kang cover sa may passenger side wheel well.
igixxi, imho get the most expensive oil na pasok sa budget, hindi naman maselan ang 4d56 sa langis, any oil will do. 15w-40 with rating of CF or higher. I use caltex delo sport for my pajero. fuel filters last 20k kms pag oem. pag replacement 10k kms
testy, buti swak yung bulbs,
jhong8, check mo idle baka masyado mababa. mali yata napalitan mo bro, dapat engine support. kamusta condition ng engine? like kumakain na ng langis? or when wa your last oil change. did you use oem support? or baka di ka sanay sa diesel.Last edited by promdiboy; September 6th, 2009 at 11:11 PM.
September 7th, 2009 04:25 AM #4510
oo nga eh, buti swak yun bulbs sa climate controller. nag-diy nga kami ni erpats nyan nung time na hindi ko pa nabibili yun 4 na bulbs, ginawan muna namin ng paraan. gumamit ako ng t5 bulbs, yung maliit na peanut bulb. sad to say, nahihirapan magcontact sa pcb board ng climate controller. sabay mo pa yun pagka-busted ng ilaw ng rear ac controller. so ayun... yung 2 bago, nasa climate controller. tapos inoperahan ko yun oem radio niya para kahuyan ko ng bulbs at good to say, buo pa ang mga ilaw niya at sakto pang replace sa ibang busted lamps
How about 97 LXi?
Civic horsepower
