Page 442 of 660 FirstFirst ... 342392432438439440441442443444445446452492542 ... LastLast
Results 4,411 to 4,420 of 6591
    Jun 2009
    #4411
    Anybody out there!!
    Lately I'm experiencing strange noise when I turn my steering wheel, hindi naman permanente iyung ingay, kaya lang there are instances if I turn slightly to the left, parang nag metal to metal noise tapos mawawala. I checked the power steering oil okey naman ang level, but down the motor itself a slight streak of oil is noticeable . any similar experience ? & what corrective action you have applied.
    Thanks. RTS
    Apr 2008
    #4412
    Quote Originally Posted by badongski View Post
    ito na yun pics. medyo natagalan
    I told you sir badongski, maganda nga sa fieldmaster! My ride is black, kaya maganda chrome... san nyo nabili and how much? thanks for the picture!
    #4413
    Quote Originally Posted by RTS View Post
    Anybody out there!!
    Thanks. RTS
    check mo ang steering gearbox. you said may nakikita kang streak of oil, it is possible may leak ang steering gearbox mo. solution dyan, o-ring replacement. replace all possible worn out o-rings. kami kasi before, nagpalit na ng lahat ng o-ring pero may nakita pa rin kami leak. last solution mo will be, you'll end up buying a repair kit consisting of o-rings and oil seals para sa gearbox mo.
    #4414
    Quote Originally Posted by Mitsu_Addict View Post
    * Testy... ok po... will look into how i could add Highbeams. Kanina ngcheck ako ng sang delica with projectors parang maliit masyado yung unit eh... mukhang di bagay sa laki ng headlight housing ng pjero natin... Hahay... settle muna ako sa Halogens till magkabudget.
    measure mo ang diameter ng projector ng delica. yung sa akin kasi, 2.5" ang diameter niya. i was opting for a 3" projectors pero mas madugo ang price nun, 20k daw, projector palang daw yun.
    Aug 2007
    #4415
    VERY NICE SIR...........
    #4416
    Good day sa inyo fellow pajero owners, just new here, pero very much excited to know more about pajeros, seek lang ako ng assistance nyo po, meron akong fieldmaster gdi v6 engine, ayaw na tumuloy yun andar ng makina, para daw naghahalo yun gas at langis, may white smoke sya sa likod, can anyone help me find a tried expert fieldmaster mechanic...
    taga las pinas lang po ako
    Sep 2008
    #4417
    Quote Originally Posted by ebr View Post
    try searching for Joseph Autotubo in your search bar, If I remember correctly his shop is in multinational village.
    good luck!
    #4418
    Gotcha, thank you for the quick assistance, just texted Sir Joseph kaso he does not do home service daw, since d ko mapatakbo yun FM ko d ko madala ang FM ko to his shop/place... Sana maawa sa kin si sir Joseph...
    Any other tried and tested good FM mechanics you personally had dealt with?
    Aug 2009
    #4419
    mga sir need your expertise for gen 2 pajero manual.... medyo normal po ba yung tranny ko? kasi po sinubukan ko po shift yung 4x4 stick, up to the lowest gear which is 4L parang hirap sya tumakbo then matigas lumiko? medyo tumatakbo lng sya pag straight yung dadaanan, my problema po ba 4x4 tranny ko? have you experience this kind of situation? ..... tnx po
    #4420
    bro, wag kang gagamit ng 4L pag nasa patag ka. pwede pa ang 4H sa patag, wag lang ang 4L
