Results 4,331 to 4,340 of 6591
- Apr 2008
- 210
August 15th, 2009 06:39 AM #4332
taz13, tatanggalin mo buong panel. also remove yung bench seat and 2nd row seat belt. 6x9 ang speaker dun,
ganito itsura, nilgyan ko ng foam in between plus yung deadening para mas tahimik.
- Apr 2008
- 210
August 15th, 2009 08:41 AM #4334
Guys nakababa na yung engine ng gen 2 ko may alog na rin yung mga piston. Aside from the machine shop parts and belts to be replaced can you help me kung ano ano kelangan palitan/clean para maging fresh and di masayang yung labor ko.
1. turbo- may nag DIY clean na ba nito or should i let the expert do this?
2. glow plugs- palitan ko na din to
3. injectors- can this be cleaned?
4. radiator- overhaul
5. ?
Add na lang po kayo kung ano pa kulang. And can you suggest where i can source parts in Banawe that sells OEM parts aside from El dorado. Thanks po
August 15th, 2009 09:58 AM #4335
sir freeloader, try motorix sa banawe. mitsubishi parts dealer sila
August 15th, 2009 10:10 AM #4336
August 15th, 2009 03:38 PM #4337
taz13, Flashbond lang ginamit ko. yung ginagamit sa bubong pag may tulo. 600 per roll sa Ace hardware or handyman meron nito,
freeloader, engine supports siguro. timing belt waterpump tsaka mga hoses ng radiator.Last edited by promdiboy; August 15th, 2009 at 03:43 PM.
- Apr 2007
- 27
August 15th, 2009 05:44 PM #4338Hi Pajero Owners.. Where can I buy replacement engine support and transmission support for the Pajero FM 4M40 engine? Will this replacement supports last? Or better buy nalang the original para mas matibay? Contact numbers of the store will be appreciated. Thanks you..
August 15th, 2009 08:37 PM #4339
i usually buy engine support sa.. suki kong tindahans.. i just buy... replacements...
i specify for japan replacements..
i do not know if they are real japans.. they may be hi quality taiwan/china but.. it doesnt really matter to me.. since.. tumatagal naman..
mahal ng original eh.. hehe
btw mga sirs... assuming a pajero has 4 bnew tires.. and the owner did not rotate.. which mauunang maubos? harap or likod? if... lagi naka 2 wheel drive mode.. thanks
- Apr 2007
- 27
August 15th, 2009 08:51 PM #4340Thanks sir ac! How much does it normally cost for the two engine and one transmission supports?
Sirs, okay ba to install the front pajero fieldmaster chin? What are the pros and cons if I install it? Is it just an aesthetic accessory? Thanks!
How about 97 LXi?
Civic horsepower
