Results 4,041 to 4,050 of 6591
July 20th, 2009 10:26 AM #4041
Hello there.
Mine is 2.8L /FM/Manual,4x4, I seldom use the 4x4 but recently due to flood & wet road, i tried to shift to 4x4, what I noticed is the engage lamp w/ color like amber is always on when engaged to 4x4, is this normal dahil sa matagal ko ng hindi na gagamit ,Im not sure if that is normal.
I also noticed that the forward green light is busted when shifted to 4x4, how do you change the forward green light of 4x4 indicator, do I need to remove the dashboard?
Thanks for any inputs regarding this queries.
RTS
July 20th, 2009 10:47 AM #4042
thank you sir. pero nung naghanap ako kahapon, walang maipakita sa akin na cp-05. iba ang pinapakita sa akin, pr-165 ata yun kung hindi ako nagkakamali, at ang mahal pa. sana sa banawe eh meron nyan.
hindi normal yan sir. kasi it only mean na ang center differential mo eh locked. baka naman sir, gumamit kayo ng 4wd at na-shift ninyo sa 4llc o 4hlc mode? dapat pag ganyan lang, 4h mode lang dapat kasi not advisable ang 2 other modes sa paved roads. tapos sir, kelangan baklasin ang dashboard pag magpapalit ng ilaw. pero madali lang naman yan sir, wala pang 15 minutes ang magbaklas ng dash
July 20th, 2009 12:29 PM #4043
*Testament11
Thanks for your response, I will try this afternoon to move or shift the dual stick from 2wd-4wd-4wdlo,etc & find out if the amber light will be extinguish, pag I shifted to normal 2 wd nawawala naman iyung ilaw, only when I shift it to 4wd saka lang nag iilaw(blinking).I wil try the dashboard when I have time.
Thanks again ,-RTS
- Jun 2006
- 24
July 20th, 2009 01:08 PM #4044[QUOTE=testament11;1276192]naku sir drake, kami lang ng erptas ko ang mekaniko niyan. kaya naman kasi namin ma-identyfy ang problema at kami nalang ang tratrabaho.
thanks testi.recently na experience kong nag leak yung sunroof ko.eventually pag bukas ko sobrang dumi and naipon yung parang putik sa loob.ginawa ko nilinis ko mga railings and drainage and put grease ulit,hopefully di na mag leak.though parang may na vibrate dun sa glass pag naka drive ako,weird.pag nagbabawas ba ng tubig radiator ko may tama na yung water pump?araw araw nag top up ako ng tubig,wala naman butas yung radiator hose.
July 20th, 2009 01:22 PM #4045
sir drake, tumulo na naman ang sunroof ko. wala naman bara dun sa drainage ng sunroof ko. pero ang possible culprit ko, eh yun goma na ang may sira. imagine, sa tagal na ng sasakyan, malamang worn out na ang goma. baka one time nga, papalitan ko na yun goma nun at yun motor ko, may kahinaan na.
re: water leak mo sir, have you tried checking yun mga hose niya? baka naman may butas na rin yun hose nyo sir. pag wala, check water pump. pag yan basa, yun na problem mo. possible na yun o-ring nun eh bumigay na. hope this helps...
July 20th, 2009 02:50 PM #4047
July 20th, 2009 03:19 PM #4048
- Jun 2006
- 24
July 20th, 2009 03:19 PM #4049thanks testi will do.regarding sa goma,meron kaya yung auto glass shops na goma for the sunroof,para mapalitan ko na rin.saka yung vibration ko pala sa glass ng sunroof nangyayari kapag nakatodo sara sa sunroof switch.nakita ko lang kanina.kaya leveled lang ang pag sara ko.pag nag leak pa papa seal ko na yung sunroof para di hassle.
July 20th, 2009 03:43 PM #4050
last option mo ang ipa-seal ang sunroof mo. better have it fixed. ako kasi, kung ano ang mga nasa sasakyan ko, eh essential. kaya nga yan nilagay kasi may purpose yan. plus porma din kasi ang sunroof pero hard to maintain gawa ng tulo. kung mapapaayos mo, sabihan mo ako ah para ako din magpaayos
it seems this company is slowly dying.... only service for Metro Manila will now be in Alabang only...
Volkswagen Philippines launches 5 new competitive...
